295/60r15 cooper cobras on stock rims?
Old Dec 17, 2013 | 09:15 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I'm looking into a new set of cooper cobras all around my car. Iv got the original stock Aluminum 5 spoke Camaro wheels off an 88 sport coupe. Can I run 295s safely on the rear wheels?
Old Dec 17, 2013 | 09:22 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: 295/60r15 cooper cobras on stock rims?
My back wheels are 15x8's and 275/60s are all that I can fit on them without rubbing or bulging out the sides. I don't think you can wrap 295/60's around a 15x7 safely.
To run 295's you probably want something like a 15x10 back wheel, with proper backspacing. Maybe even air shocks, I don't know.
Old Dec 17, 2013 | 10:17 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
295 is a wide tire, a full 80mm wider (3.2") than the stock 215-65-15 tires that came on those wheels from GM. The tires are too wide for the wheels.
You would need to move to a 10" wide wheel, which can fit with the right BS.
Also keep in mind that a 295-60-15 tire is 29" tall - a full 3" taller than stock...
Old Dec 17, 2013 | 11:57 AM
gt4373's Avatar
Transmission: 5-Speed Manual
To Much Tire For A Stock Suspension 3rd Gen.
Old Dec 17, 2013 | 12:07 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
That's about what I need :-o ... What do y'all think I can fit on my stock height (with new springs n shocks) 18*9.5 wheels ? Nothing is stock . Tubular control Arms panhard Torque arm etc all adjustable except torque arm
I have 225/45/18 right now and I wanna go about 2-3" wider and 2 taller
Old Dec 17, 2013 | 12:32 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
295/50/15 is right around 26.8 depending on brand
Coopers are the narrowest/shortest pretty sure anyway of the 295/50 sizes. Getting them on an 8" wheel is pushing it. Sidewall will roll a lot so you wont get full contact patch unless you go to a wider wheel. Underinflation+rolled sidewall not good news
Had looked into them just for some cheap street tires to burn up not so sure if runing them on an 8 is so smart
Old Dec 17, 2013 | 04:56 PM
Engine: L31 350
So what's the widest I could go for the rear? I'm just looking for a bigger tire look. Iv got the 215/75/r15s now and hate how skinny they are but I love the wheels.
Old Dec 19, 2013 | 02:16 AM
Axle/Gears: 4.11
Are they 15x7 or? Im not hip to the wheel size differences of these cars. an 8 " rim is barely wide enough, 7 no. 255 tops
Old Dec 19, 2013 | 02:56 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
I ran 275's on a z28 rim
Old Dec 19, 2013 | 06:24 AM
Engine: L31 350
this. This is what I'm after. The look of the tires are just perfect
Old Dec 21, 2013 | 02:57 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If you want a decent size for a street tire/primarily street car than this is what I recommend.
If you do get the Cooper Cobras than you have the choice of black or white letters out. Black out IMO looks much cleaner on a Third Gen.
Link to see tires = https://www.thirdgen.org/forums/whee...er-cobras.html
Old Dec 23, 2013 | 12:06 AM
Engine: L31 350
Decided to go 235/60r15 cooper cobras. Almost went 215/65r15s on the front and the 235s on the back but was unaware of the look. Paid about $416
Old Dec 23, 2013 | 12:08 PM
PATRIOTIC1911's Avatar
Car: 91 Firebird
Engine: 305 TBI
Please post some pics once they are installed. I'd like to see how it looks. I'm in the process of figuring what wheel/tire routes I want to go with my Firebird. I know I'm keeping with 15" wheels.
Old Dec 23, 2013 | 07:49 PM
Engine: L31 350
Will do. I'm ordering from treaddepot
Old Jan 2, 2014 | 06:58 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Just picked up a set of MT Drag Radials 325/50/15 $300 brand new SHIPPED got them in 2 days..love ebay
wanted to use them at the track over the MT Sportsmen Pro 29/12.5/15
10.275 wide wheel. (6.5 BS)
Old Jan 5, 2014 | 09:38 PM
Engine: TBI,5.0
You are one of the very few that can make that size tire work and look "REALY GOOD" doing it.
Nice ride
Old Jan 7, 2014 | 02:07 PM
devestator_x's Avatar
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
I have 235/60R15 Cobras on stock 7" Z28 rims on all 4 corners. Dont have rim specific pics right now, but these might give you some ideas.
Old Jan 8, 2014 | 06:20 PM
Car: 91 Firebird
Engine: 305 TBI
Those 235s look good.
Old Jan 9, 2014 | 07:16 PM
92fastNloud's Avatar
Car: 92 RS 25th anniversary
Engine: 305 TBI
Transmission: auto
Can some one help me. I bought a set of 295 50r 15 for the rear and a set of cragar ss 15x8 with 0mm offset and 4.5 b.s. Now after reading some of the treads i am not sure they will fit
Old Jan 9, 2014 | 08:21 PM
Engine: TBI,5.0
Have they been mounted to the wheel yet? If so they are most likely not returnable so do not mount them yet if not.
I have seen them once on a 15x8 with 3 3/4 back spacing wheel. They did not rub but that's a miracle because the tread was 3/4 out past the flair and the bulge was 1 1/4 out past at its widest point. Your 8in 4.50 bs will tuck the tread in 3/4in. more.
That would put the tread right on the edge of the flare not inside it.
A 295/50R15 tire should be mounted on at least a 10in. wheel. The one I saw was ballooning pretty bad.
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Genopsyde
Oct 7, 2015 08:35 PM
Randomtask2
Aug 13, 2015 01:57 AM
Exxon Limited
Aug 9, 2015 08:13 PM
