Compressed air canister for spare????
Old Aug 4, 2015 | 05:52 PM
tooltime's Avatar
Car: 1992 RS Polo Green Coupe 86 IROC
Engine: 305 TBI
Transmission: Automatic
Axle/Gears: Yes it has some!!!
Hey guys, I have a 83 Z28 and I had a flat. I pulled the spare, that was sucked flat and rolled into itself and inflated it with the canister. I was blown away, 32 year old canister worked. Now what. Where do I get a replacement? No one can fill it that I know of. Has anyone run into this and if so, what is the answer? Let me know. Matt
Old Aug 5, 2015 | 11:48 AM
Kblakney's Avatar
Car: 1991 Z 28
Re: Compressed air canister for spare????
i have one i just removed from my 91. pm me if interested, i will never need it.
Old Aug 23, 2015 | 09:34 PM
tcarlos13's Avatar
Car: 1992 Heritage RS Convertible
Engine: 305 H.O.
Transmission: 5speed
Try going to a supply house that sells compressed gas cylinders. You can google it. Airgas is a popular vendor nationwide, but there are others. They can sell you similar cylinders close to the same size or at least the same capacity as the original. Hope that helps you.
Old Aug 24, 2015 | 09:13 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Does Anyone Know Why These Can't Be Refilled,Does It Take Specialized Equipment.
Old Aug 24, 2015 | 10:21 AM
tcarlos13's Avatar
Engine: 305 H.O.
Yes, compresed air cylinders all have a life span. Some have dates stamped on them. These types of cylinders can be refilled as long as the hydro dates are good. Other compressed gas cylinders like the ones in this thread are not meant to be reused. They are disposable, one and done. I would be surprised to find a supplier that would refill it, especially one that is that old. Best to get a new refill bottle in case of a flat and keep the original for display purposes. Hope that helps.
Old Aug 24, 2015 | 11:28 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
You could just go to any junkyard and get a bicycle spare, they were an option and fit in the same little space.
Old Aug 27, 2015 | 07:49 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
From what I'm hearing , a fire extinguisher service company will fill them.I never had one filled but,that's what I'm hearing.
Old Aug 28, 2015 | 05:33 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Something like this thrown in your rear storage compartment should do the job.....
Amazon.com: LifeLine AAA 300 PSI 12 Volt DC Air Compressor: Automotive Amazon.com: LifeLine AAA 300 PSI 12 Volt DC Air Compressor: Automotive
Old Aug 28, 2015 | 07:28 AM
mantaguy's Avatar
Engine: 5.0 EFI
I would feel more comfortable with the pump on a road trip.
Old Jan 6, 2016 | 04:21 PM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
did you find anything? I just use my 27 Year Old one and need one too
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Genopsyde
Aug 22, 2015 06:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
