Swapping stock tire sizes....
My 92 Z has the 245/50/R16 tires on the car... as it came from the factory... I have the chance to buy four decent rims with decent 235/55/R16 tires on them which was also stock.. but on the RS i am guessing... as i calc it, this will result in a different sidewall height... can they be one-for-one swapped or will this screw up the speedo setup?
Anyone try this yet?
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: Swapping stock tire sizes....
I swapped a set on my fronts years ago that I got from a buddy who was having a new set put on and his fronts were still good. I’d have to check but I believe the overall difference between the two is so small you may not notice. It has a higher profile but narrower width so I believe overall height is close to same.
I just went and checked and it looks to be about a half inch difference. Keep in mind this is total diameter so your ride height and clearance will diminish by half that. Not much at all.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Something else to keep in mind is the fact that actual tire dimensions will vary slightly between various manufactures' tires, even for identically-listed sizes. IOW, if there's some doubt, measure the tire(s) in question in-person.
CKone (05-08-2020)
Green92RS305
03-10-2005 01:09 AM
