Wheel offset
Old Sep 20, 2022 | 11:34 AM
79bigchief's Avatar
Wheel offset
I have a 1988 IROC with a stock length Ford 9”
I’m mini tubbing the car. It has ladder bar suspension. I need to know what the back spacing on my wheels need to be in order to fit a 275/ 60/ 15 drag radial
Old Sep 20, 2022 | 12:58 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Wheel offset
You speak as if there's only one "stock length" for a Ford 9"...
Old Sep 20, 2022 | 02:11 PM
79bigchief's Avatar
Re: Wheel offset
it’s the stock length that comes on the Camaro
Old Sep 20, 2022 | 07:03 PM
T.L.'s Avatar
Re: Wheel offset
Okay, my bad! That sounds awesome. Hopefully someone here knows what wheel backspace you need...
Old Sep 20, 2022 | 09:05 PM
79bigchief's Avatar
Re: Wheel offset
No worries. Appreciate the input.
Old Sep 21, 2022 | 12:28 PM
Abubaca's Avatar
Re: Wheel offset
You'd almost be able to do that without tubbing. Can't quite say for sure. A 275mm with a stock height of 26" fits on a 0mm offset wheel just fine. You're tire is at 28". -Half on bottom, half on top, so really only 1" difference from stock. That's darn close to fitting both on the inside AND outside of the car. Since you're tubbing, and you know you'll have plenty of room inside the car, I might just go with a little more positive offset than a stock 0mm. Move the wheel IN just a little. Exactly how much though? I feel like you either need someone is direct hands on specs who has done it before, or you just need to take real world measurements and see what fits.
Old Sep 21, 2022 | 01:53 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Wheel offset
I am tubbed, stock length rear, and still had to measure. Wait until you are able to get all your dimensions, measured, not theoretical, and then measure to see what you can fit. If you are going to run a pretty tall tire, you're going to want to tuck the wheels a bit more or you'll cut them on the wheel well lip.
Old Sep 21, 2022 | 03:36 PM
79bigchief's Avatar
Re: Wheel offset
I really appreciate the advice guys . Thank you !
Old Oct 27, 2022 | 08:39 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Re: Wheel offset
I have a stock width to a third gen Currie 9" Ford in my race car. My rear wheels are 15x8 with a 4.5" backspacing. Running a 275/60/15 Mickey-Thompson ET Street SS drag radials. I have zero clearance issues
Old Oct 27, 2022 | 09:24 PM
79bigchief's Avatar
Re: Wheel offset
I really appreciate you! Thanks for the input.
Are you running a disc or drum brake ?
87TCamaro
Wheels and Tires
Mar 5, 2021 03:45 PM
joshfgilmer
Wheels and Tires
Aug 6, 2012 10:53 PM
cookie21
Wheels and Tires
Feb 6, 2012 07:10 PM
sbchevyz28
Apr 20, 2004 08:27 PM
94-6spd
Jul 20, 2003 12:55 PM
