Spare Tire Options - 91 Formula
Old Oct 6, 2022 | 04:14 PM
Scotty54's Avatar
Car: 91 Formula
Engine: 2005 LS2
Transmission: 2002 T-56 6-speed
Axle/Gears: 4.11
I have the original empty spare and long expired fill can so basically I have no spare tire. I would like to take the Formula on 2-3 day jaunts through our web of glorious mountain roads (TN and VA) but would prefer to have a functional spare, even just to get me to the next town.
Is there a "donut" spare that will fit in the spare tire well, or some other option?
Old Oct 6, 2022 | 07:33 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Spare Tire Options - 91 Formula
newer cars... or at least I know the 89 V6 had an actual sapre. I think they did away with the inflator or only had that in the higher performance models...
you could also just pack a air pump... but you could only drive so far if you have a hole though
Old Oct 7, 2022 | 10:47 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Buy an extra spare front wheel, throw a tire on it and toss it in the hatch.
Old Oct 7, 2022 | 01:48 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
^this.
Could even snag a smaller 6" wide rim off an S10 or something.
Old Oct 7, 2022 | 01:57 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Carry a pump in the car: a bicycle hand or foot pump, or a portable rechargeable electric pump. The original collapsible spare is likely to have cracks in the sidewalls when you inflate it, but it should still hold air and get you up the road to a place that can replace your flat tire.
A lot of late model cars don't come with spare tires, so a Corvette owner created this business:
Engineered Spare Tire Complete Kits For Modern Vehicles | Modern Spare
I've contacted them twice, but nobody gets back to me. Such a spare could be carried in the back of the car daily or just for road trips.
Some people have created their own similar spare by getting a front drag wheel of, say, 4" to 5" wide, with an appropriately sized tire mounted on it.
Old Oct 7, 2022 | 03:58 PM
Scotty54's Avatar
Car: 91 Formula
Engine: 2005 LS2
Axle/Gears: 4.11
I found an older thread on this very issue and found several other suggestions. For now I have purchased a used 4th gen spare from Hawk's. It won't fit in the spare tire well but at least I have a spare in the meantime. I like the idea of a drag wheel and skinny tire - I really want to find one that fits in the tire well.
Old Oct 7, 2022 | 06:36 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Why not just look for the 3rd gen V6 spare then? It will fit in the V8 or V6 spare tire area, and if you find one in a junkyard, you'll likely find all the parts to make it attach to the stock parts and wil lfit right under the trunk plastics.
I have one, and its quite light weight and compact compared to a full size. and will save you the storage area. I never compared the equipment to the stuff from my inflatable spare, but I imagine itll be the same so youd just swap the tires out...
You need to remove the tire rest that the inflatable tire rests on though since the V6 spare is essentially always inflated and the rest would get in the way.. The V6 spare just sits on the bottom of the quarter
Old Oct 8, 2022 | 08:15 AM
Scotty54's Avatar
Car: 91 Formula
Engine: 2005 LS2
Axle/Gears: 4.11
I did not know that the V6 cars had an inflated space saver. That's definitely something I will pursue. Thanks for the replies!
jaykar
May 25, 2021 06:11 AM
mav75
Wheels and Tires
19
Nov 24, 2012 12:59 PM
Reid Fleming
Sep 28, 2007 07:34 PM
L.I.N.Y.92CAMARO
Apr 20, 2007 10:44 AM
91ZDROPTOP
Convertibles
Jul 15, 2004 06:59 PM
