Space Saver Spare Tire Inflater Bottle Question
Old Nov 23, 2012 | 07:54 AM
mav75's Avatar
Car: '89 Trans Am
Transmission: 700 R4
Does anyone know what the useful service life is for the inflater bottle that comes with the spare tire? My car was built in late '88, and I don't think the bottle's ever been used. Do they lose their charge like fire extinguishers? If so, how can I get a replacement bottle without having to buy a spare tire to go with it? Come to think of it, does anyone think the tire might be dry rotted and need replacement also?
Thanks!
Old Nov 23, 2012 | 08:56 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Space Saver Spare Tire Inflater Bottle Question
As Long As The Inflator Valve Was Sealed And Had No Leaks,It Will Probably Out Last The Car.
Old Nov 23, 2012 | 09:05 AM
mav75's Avatar
Car: '89 Trans Am
Cool…how about the tire?
Old Nov 23, 2012 | 09:11 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
The tire should be ok if it wasn't stored outside. You can inflate it with a compressor and deflate it again to check it.
Old Nov 23, 2012 | 09:23 AM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Don't know if they still do it, but could get them checked/refilled at Chevy dealerships in the past. You might also check around at places that handle commercial bottled gas and fire extinguishers. It's just CO2 in there, if they have the right fittings, they should ne able to refill it if needed.
Old Nov 23, 2012 | 10:58 AM
mav75's Avatar
Car: '89 Trans Am
Good point! AFAIK, the tire had been stored in the trunk the whole time the first owner had it. When I checked inside the storage area, it looked to me like it had never been removed.
I was thinking about going to a Chevy dealer to have them check the canister. It's a GM part, so they should be able to help. Knowing dealers, they'll try to sell me a new one anyway.
Old Nov 23, 2012 | 11:20 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Good luck! I stopped by a Chevy dealer, but they had gotten rid of their CO2 machine about 15 years ago. Discount Tire had never even seen something like this before. They did think the deflated spare tire was rather cool when they aired it up for me.
I tried a paintball place. But their adapter was the wrong size for the bottle.
In their time, the CO2 bottle was a great idea. Because it's exactly what's needed to fill up the spare tire. No more. No less.
Old Nov 23, 2012 | 01:45 PM
mav75's Avatar
Car: '89 Trans Am
So you used your canister and then went to Chevy for a refill?
Not that it matters anymore, since I keep an air compressor that runs off my cigarette lighter in the car. It looks like just a regular valve on the tire, so there shouldn't be any issues.
Old Nov 23, 2012 | 03:54 PM
Car: 1989 GTA
I used my CO2 bottle in 2007 and have yet to find anybody that can fill it. I keep a portable power pack in the trunk area in case I need a tire aired up or a battery boost.
Chevy dealership couldn't help me. I should ask the fire department if they have any way of re-filling it.
Old Nov 23, 2012 | 06:12 PM
mav75's Avatar
Car: '89 Trans Am
There are quite a few canisters available on eBay, but the only ones I've seen are in "used" condition. To be honest, my major concern was staying completely original, but I'd rather count on a compressor that I know works than trying to replace a 24 year old CO2 bottle with one I wouldn't be completely comfortable with.
My real concern is the tire, which I can inflate in a day or two to test. Then I'll go from there.
Old Nov 23, 2012 | 09:07 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You could weld a small bung to the canister to get a schrader in there to make getting it filled easier, or find a local small machine shop and have them make you an adapter to thread into it for filling.
Old Nov 23, 2012 | 10:58 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
My spare, jack and inflator bottle have never been removed from my 84.
No idea if the bottle is any good.
I just carry a can of fix o flat just in case......................
Old Nov 23, 2012 | 11:45 PM
Car: 1989 GTA
You'll be quite surprised to watch it inflate. It will seem like it's going to pop right off the front of the wheel when you inflate it. And then at the very last second, it sucks itself back to where it should.
Old Nov 23, 2012 | 11:51 PM
mav75's Avatar
Car: '89 Trans Am
Probably not a bad idea...
Thanks for the heads up; I would've freaked!
Old Nov 24, 2012 | 02:14 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
One of the first things I did when I bought my used, 18 month old IROC was purchase a portable air compressor. I never trusted myself with using that can of C02. I figured on a dark and lonely highway, it's a one shot deal. There were no cell phones back in 1989.
The second thing I did was make sure the compressor I purchased would fill up the tire before the sun came up.
So far, I've never had to use either the spare or the compressor. Hmmm....I wonder if the compressor still works?
Old Nov 24, 2012 | 07:29 AM
mav75's Avatar
Car: '89 Trans Am
I got mine at Wal-Mart for about $15 - $20 in case yours doesn't work anymore. There are more powerful (expensive) ones, but the one I got is just fine for the size of the spare tire. I've used it to fill my tires back up after a cold night. It works pretty well.
Old Nov 24, 2012 | 08:52 AM
stealtht/a's Avatar
I have several canisters, I was waiting to see if I could find a place to refill them, but if I can't find one, I'm going to test one soon. I'll take vid, maybe Sunday.
Old Nov 24, 2012 | 09:22 AM
gt4373's Avatar
Be Sure To Wear A Pair Of Gloves Those Things Get Cold As Hell In Seconds.
Old Nov 24, 2012 | 09:53 AM
kciaccio's Avatar
I would check your spare anyway. When I inflated mine it was lopsided and could not be fixed.
Old Nov 24, 2012 | 12:59 PM
mav75's Avatar
Car: '89 Trans Am
It's on my short to-do list...ahead of the honey-do's
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
