Wheel sizes??
Old 04-20-2023, 02:13 PM
19eighty4_z28's Avatar
Car: One Chevy built
Engine: Chevy crate 350 DRESSED UP!!
Transmission: 700r4 rebuilt from solid chrome
Axle/Gears: Why does it matter to you?
Wheel sizes??
I have an ‘84 Z28. Does anybody know what is the max wheel size I can put on the car without having to mod anything. Stock suspension (rebuilt) all the way around. It’s got 15x7 now but those are baby pizza cutters and gotta go. Thanks for any advice!!
Old 04-20-2023, 02:39 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Re: Wheel sizes??
I put 16 X 8, 245/50-16 back in the '80's. They fit great, but they rubbed in front at full lock until I put an IROC steering box in, that fixed it.
Old 04-20-2023, 03:24 PM
russ89gta's Avatar
Car: 1989 pontiac trans am gta
Engine: tpi 5.7
Transmission: th700r4
Re: Wheel sizes??
I just put 17x9.5 CTW wheels on my GTA. No modifications needed.
Christopher (05-04-2023)
Old 04-20-2023, 05:12 PM
Re: Wheel sizes??
thanks. Curious but what size tires did you run on those 17’s?
Old 04-20-2023, 07:55 PM
russ89gta's Avatar
Engine: tpi 5.7
Re: Wheel sizes??
275/40/17
19eighty4_z28 (04-21-2023)
Old 04-21-2023, 02:05 AM
Re: Wheel sizes??
Awesome! GTA…you alright
russ89gta (04-21-2023)
Old 04-27-2023, 12:47 PM
rsloan's Avatar
Re: Wheel sizes??
87Z, 17X9 with 5.5 offset on rear and 17X8 with i think 5 inch offset in front. 275 40 17 rear/245 45 17 front. The rear housing is off a 1998 Camaro.
Old 04-27-2023, 12:56 PM
rsloan's Avatar
Re: Wheel sizes??
Correct, back spacing is what I meant. And yes, the front is taller. Not by much considering its a 245 vs. 275.
Old 05-03-2023, 10:34 AM
Beater79TA's Avatar
Re: Wheel sizes??
If hitting a few spots with a hammer doesn't count as modding, you can go as wide as 18x11 with the wheels and fit some brands 315/30/18. Far less expensive to stop at 17x9.5 and run a 275/40/17 though.
Old 05-04-2023, 09:11 PM
Christopher's Avatar
Car: 1991 Z28 1LE
Transmission: 5 spd
Re: Wheel sizes??
I recently put CTW's on as well along with Firestone Firehawk Indy 500's 275/40 17.
The following 2 users liked this post by Christopher:
19eighty4_z28 (05-05-2023), russ89gta (05-04-2023)
LGS_18
Wheels and Tires
09-10-2023 02:42 PM
itsMikey
Wheels and Tires
33
11-18-2021 12:49 AM
Kandied91z
12-28-2002 03:32 AM
Jim85IROC
03-12-2002 07:15 AM
Quick Reply: Wheel sizes??
