BMW RIM THAT FITS
Old Nov 26, 2023 | 11:07 AM
matt12ar's Avatar
Car: 1991 firebird
Engine: magflatoVE
Axle/Gears: magflato
BMW RIM THAT FITS
I know this will ruffle a few Feathers.but if your looking for a super cheap way to have 16 inch wheels and tires BMW e46 sedan rims can be Sourced extremely cheap. I got to set of 4 for $100. You will need a 2 inch wheel spacer This opens the door for more easy and affordable tire optons.Pictures below show ZERO RUB tire is 205/55r16
the reason for the spacer is for the 40mm off set the bmw wheel has.if you dont use the 2 inch spacer the rim will contact the tie rod
"1991 pontiac firebird formula
stock suspention
Stock disk front drum rear"
This is an option for people looking for a upgrade/cheaper tire option as of 2023
Old Nov 26, 2023 | 02:03 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: BMW RIM THAT FITS
LOL, I keep my 3rd Gen parts on one side of the garage and my BMW parts on the other.
Old Nov 26, 2023 | 02:15 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
BMW rims only fit BMW wheels...
Attached Thumbnails BMW RIM THAT FITS-61912c38-97e8-43a3-8d90
Old Nov 26, 2023 | 03:47 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Is the bolt pattern the same or is the spacer converting from one pattern to another? I know the two patterns are really close but not perfect, at least so I hear.
Old Nov 27, 2023 | 07:18 AM
matt12ar's Avatar
Car: 1991 firebird
Engine: magflatoVE
The e46 rim will fit i used a spacer due to the 40mm off set. Without the spacer it will hit the tie rod
Old Nov 27, 2023 | 07:38 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Not my thing, but nice of you to share the info. Probably a few guys interested in this even though they won't admit it in writing.
Old Nov 27, 2023 | 07:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
That's what we call "fits" these days? Wrong offset, wrong bolt pattern and wrong hub bore....
Now that's tha.of the way, guys have been runnign BMW wheels for a long time. I had a set on my old 92, just a tad larger at 18x10.5. There is an old thread in fabrication IIRC about correcting the bolt pattern.
Old Nov 27, 2023 | 09:37 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Difference in the 2 patterns is a total of about .025". That doesn't sound like a lot BUT it WILL put stress on the wheel studs during cornering, especially hard cornering. And you can only stress metal back and forth so many times before it breaks.I would make sure at minumum you are using hub centrics to make sure the wheel is centered.
gsxrfann
Wheels and Tires
May 6, 2012 09:28 PM
kowboy59
Dec 2, 2007 12:23 PM
o2b18
Apr 13, 2006 01:08 AM
wstdintllgnce
Dec 13, 2005 07:53 PM
therckid
Feb 11, 2004 10:48 PM
