C6 wheels on a third gen with a 4th gen quick Performance 9".
Old Dec 20, 2023 | 03:35 PM
Groot's Avatar
Looking for pictures mainly. I have an '86 IrocZ. I purchased the C6 wheels. I have also purchased a quick Performance 9 inch rear end. I'm curious if any one has pics of this similar set up. Or send me a link. Thank you
Old Dec 20, 2023 | 08:02 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: C6 wheels on a third gen with a 4th gen quick Performance 9".
What width did you spec the rear at? If you spec'd it 4th gen width they will bolt up with an inch spacer. 3rd gen rear, and you'll need 2" spacers.
Old Dec 21, 2023 | 04:48 AM
Groot's Avatar
Thanks for reply, the rear is a 4th gen width.
Old Dec 21, 2023 | 07:14 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If they are the star pattern C6 wheels I think I ran a 1" or 1.25" spacer when I briefly ran these wheels.
Old Dec 21, 2023 | 08:11 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
4th gen spec rear plus 5/8 slip on spacer
Old Dec 21, 2023 | 11:03 AM
Groot's Avatar
First off I wanted to say, beautiful car. Thank you for the picture. My concern was that I wasn't sure if the wheels would tuck into the fender well.
Powder coated gloss black
Old Dec 21, 2023 | 11:34 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If 19x10 it depends on tire size some, but will have to hammer the front of the well to gain the clearance to really tuck them. I had the 5/8 spacer to get it about even with lip.
Old Dec 21, 2023 | 11:35 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Old Jun 7, 2024 | 09:31 PM
Groot's Avatar
Did you need a spacer for the fronts? The rim is making contact with the strut and the snout on the hub poses through the rim quite far.
Old Jun 7, 2024 | 10:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
18x8.5 fronts needed 2”. I have c5 brakes which is supposed to space out the wheels .25” or so, i have 1.7” spacers
Old Jun 7, 2024 | 11:30 PM
Groot's Avatar
I have Gen VI brembo with C7 vette rotors.
anesthes
Wheels and Tires
Apr 26, 2018 03:26 PM
bwmcam
Wheels and Tires
Jan 5, 2017 01:24 PM
Keith5
Feb 10, 2002 01:04 PM
lostangel
Sep 21, 2001 02:35 PM
