Disabled EGR...what to do with vacuum lines to and from solenoid?
Old Aug 9, 2003 | 12:11 AM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
I got a new prom with EGR disabled on it, and I just want to throw away the solenoid, but I don't have the time to take apart the intake and get rid of the EGR itself. What should I do with the three lines going to the EGR solenoid? One exits toward the back and goes around to the cruise control and vacuum reservoir, and then two come off the front - I think one turns around and goes to the cowl for some reason or another, and the other one IIRC goes to the EGR valve. I would appreciate it if you guys could tell me what I should do with these. Thanks.
Old Aug 9, 2003 | 09:46 AM
Wishmaster's87IROC's Avatar
Engine: 385 HSR.....LS1
good question cause Im not going to hook mine back up either...and I never thought about what to do with the lines coming off it...
Old Aug 9, 2003 | 06:06 PM
25THRSS's Avatar
just plug em
Old Aug 9, 2003 | 10:11 PM
jamesbob02's Avatar
Car: 92 Z28
Well the back one feeds vacuum to my vacuum reservoir and my cruise control, so I assume I should hook it back up SOMEWHERE, I just dont know where. I dont want to screw something up, because I dont understand engine vacuum and how to control it or whatever, where there should and should not be vacuum or whatever.
Old Aug 9, 2003 | 10:29 PM
is this all part of the EGR?
connection #3 goes under the TB and the connection #4 goes to the charcoal canister I think....can all this be done away with?
Can all of it be done away with? #1,2,3,4?
Attached Thumbnails Disabled EGR...what to do with vacuum lines to and from solenoid?-dsc00415.jpg
Old Aug 9, 2003 | 11:19 PM
Morley's Avatar
Cap off the lines that only go to the solinoid, for the one that goes to the cruise too, get a 90* rubber elbow fitting or straight splice fitting (Vacutight, from most any auto store) and run the line to the CC. Don't throw away the solinoid, valve and associated parts, you never know when you might find yourself having to get emmissions tested and that stuff can be hard to find and expensive.
Old Aug 9, 2003 | 11:22 PM
25THRSS's Avatar
If you don't have a charcoal canister can you just plug them all? Will the cruise still work?
Old Aug 10, 2003 | 02:23 AM
Morley's Avatar
As long as there is a vacuum source for the cruise it will be ok.
Old Aug 10, 2003 | 08:46 AM
but can I do away with all that I have in the picture? That wuld clean up under the plenum pretty damn good.....
I knowI can delete the EGR vale but what about all the other stuff?
Attached Thumbnails Disabled EGR...what to do with vacuum lines to and from solenoid?-dsc00417.jpg
Old Aug 10, 2003 | 08:51 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Axle/Gears: 3:73 Posi
Yeap. If you have the EGR removed, then yes all that can be gotten rid of. But don't trow it in the Garbage!! Send it to me
Old Aug 10, 2003 | 08:57 AM
why would you want it?
Old Aug 10, 2003 | 09:07 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Because I broke two of the Vac Lines for my EGR, and it looks ugly with the tubes I am using.
Old Dec 7, 2003 | 02:21 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
would not having the canister to TB vac hose cause starting problems? I have my vac hose on my TB blocked off should I have a vac hose goin to it. I cant get my car fired up and I removed all EGR parts and never rerouted vac lines...
Old Dec 7, 2003 | 11:59 PM
25THRSS's Avatar
blocking the vaccum port at the throttle body should be fine.
gta892000
Aug 11, 2019 11:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
TBRays98
Sep 6, 2015 05:05 PM
