Cam selection for 357 w/vortec heads
Old Feb 23, 2004 | 04:51 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Need recommendations at to what type cam use. The engine has 8.5 COmpression using 58cc heads. I have looked at LT4 Hot Cam and the ZZ4 cam. Need a cam that will break the 300+ rwhp. Also anything else that I may need to to do to the heads.
Old Feb 23, 2004 | 04:53 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i would try to raise the compression.
i am a BIG fan of the hotcam, it makes great power, and is relativily computer friendly (it will need custom tuning)
Old Feb 23, 2004 | 05:16 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yess the HOT cam!!
If you want to run 12's then get the HOT cam. Very streetable too.
Old Feb 23, 2004 | 06:31 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Re: Cam selection for 357 w/vortec heads
Wont a 357 with 58 cc heads have a higher compression ratio than 8.5?
Old Feb 23, 2004 | 07:04 PM
86z/92rs's Avatar
So the vortec heads plus LT4 Hot cam would make a good addition to the 357 block? What would the compression be?
Old Feb 23, 2004 | 08:26 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Depends on what pistons you are running. Also what 305 heads are you using? If they are from a TBI car than you are going to have a tough time of making any power reguardless of your cam choice.
Old Feb 23, 2004 | 09:04 PM
86z/92rs's Avatar
The pistons are .040 speed pro hypereutectic and as far as the heads go, they are Vortec 350 L31 head with 062 casting.
Old Feb 23, 2004 | 10:04 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Pick up some chevy high performance rags with vortec builds. Generally they pick cams right around .470/.480 lift with relativly mild duration and a low lsa which is what you want with vortecs because they make sick power under .400 lift. Nothing scary, but very streetable with good power.
Old Feb 23, 2004 | 10:25 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I thought the 062 vortec heads had 64cc combustion chambers? Well anyway I would definetly reccomend the Lt4 hotcam if you have a roller block, but your gonna need new valve springs and I think you need the guides machined for any cam over .470 lift so I would have that done with that setup and good compression( you should definetly have more than 8:5:1 , probably at least 9:5:1) youll knock down an easy 350 hp with the right intake, throttle body, and tuning. Good Luck.
Old Feb 23, 2004 | 10:37 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
They are. I hope he realizes this. i think we all thought he was using 305 heads. His compression should be around 9.3:1.
Old Feb 23, 2004 | 10:59 PM
IROCaholic's Avatar
Car: 89 Camaro RS
I actually looked in jegs at the speed pro hypereutectic pistons and the ones I saw came in 2 different compression ratios for 64cc chambers for a 350: 11:8 and 10:6. I may be wrong though the jegs I am looking at is somewhat old. do you know the part # for the pistons you have 86z/92rs because its pretty important to know your compression ratio when you build your engine especially if you may be looking up in the 10:6 area.
Old Feb 24, 2004 | 06:06 AM
Dewey316's Avatar
Car: 1990 Camaro RS
if he is really at 10.6, he is going to need a cam that closes the intake later than the hotcam.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
MoJoe
Sep 24, 2015 09:12 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
anesthes
Aug 8, 2015 09:37 PM
