confused, i wanna get the 670holley tbi but which adapter
Old May 21, 2002 | 07:35 PM
1989camarorsrs's Avatar
Ive been looking at the holley site and im confused which tbi adapter should be used, cause i know u need 2" bores for the 670 tbi so the regular performer intake for tbi wont work, so would i have to get a carb intake and use the adapters??help needed thanks all
oh yea forgot to put the holley website in http://www.holley.com/HiOctn/ProdLin...IA/Access.html
Old May 21, 2002 | 10:50 PM
r90camarors's Avatar
Engine: LO3;383tpi
Holley makes an intake for TBI with 2" bores. I forget the part number, but it is on their sight. Also, if you decide to go with the Edelbrock or stick w/ your stock one for now, the gasket supplied with the Holley 670 is actually made to fit the 1 11/16" bores (it goes from 2" to 1 11/16").
Old May 22, 2002 | 09:24 AM
i tried looking cant find it
Old May 22, 2002 | 11:34 AM
Snowdog 91 Formula's Avatar
It comes with the adapter.
It comes with the adapter provided just in case you want to use your stock manifold. Have at it!
Old May 28, 2002 | 08:52 PM
Tas's Avatar
Tas
https://www.thirdgen.org/techbb2/sho...t=TOTW+intakes
the adapter depends on what type of intake you're getting. Qjet style, squarebore.....
I got mine for $12 from www.pawinc.com
Old May 28, 2002 | 09:10 PM
I wanna get the edelbrock performer tbi intake with egr so which adapter would i need ?
Old May 28, 2002 | 09:17 PM
actualy i wouldnt need to the tbi one just the regular performer intake with egr i think in summit its part number EDL-3706, aight cool it says spreadbore flange, oh and these adapters are for 2 inch bores right
Old May 28, 2002 | 10:54 PM
Tas's Avatar
Tas
I think these are the ones for the Edelbrock performer carb intake. I'd get the coolant one. At least you have the option of running coolant through it if you want.
Old Jun 5, 2002 | 12:15 PM
mikeb1's Avatar
Holley makes an adapter to put TBI on a regular or spreadbore intake, for the spreadbore it's part # 17-41
Old Jun 26, 2002 | 02:00 PM
Audiman's Avatar
Call the holley tech dept. Did you run the holley tbi yet, how is it?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
Jorlain
Oct 8, 2015 01:57 AM
bubbaz28
Sep 18, 2015 02:09 PM
Glowsock
Sep 11, 2015 11:09 PM
