Single Turbo Setup Pictures
Old Feb 4, 2003 | 11:48 AM
zerotosixtyV8's Avatar
Car: Camaro
Anyone have pictures of a single turbo setup on their 3rd gen. Looking to get ideas on plumbing and clearance etc. If any one has a single turbo setup, what turbo trim did you use and how hard was it to fabricate the exhaust for it? Looking to run between 5-7 psi with a 9:1 compression, could I do more? All forged internals on the engine.
Old Feb 4, 2003 | 01:01 PM
Guido's Avatar
Car: 2000 Trans Am
Well, you can start with this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=118353
Plus, you can visit my webpage (in my sig) and look around.
Old Feb 4, 2003 | 01:24 PM
Car: Camaro
very nice car you have there Guido, I'm figuring I could make about 100 more HP to a 300 HP engine with a single turbo setup, T66 trim would work well for a healthy 350. Do you have a boost controller for your car?
Old Feb 4, 2003 | 03:43 PM
Guido's Avatar
Car: 2000 Trans Am
Yes I do. Its a norgren air control valve. Looks like a regulator for an air compressor or portable plasma torch. I bought it from a local industrial supplier.
Old Feb 6, 2003 | 02:08 PM
Dan W's Avatar
Here is one.
Old Feb 6, 2003 | 02:17 PM
Dan W's Avatar
Another
Old Feb 6, 2003 | 02:20 PM
Dan W's Avatar
Yet another
This is the cleanest one I've seen. His headers resemble block huggers.
Old Feb 6, 2003 | 02:22 PM
Dan W's Avatar
Another, not as nice as the others
Old Feb 6, 2003 | 02:27 PM
Dan W's Avatar
another of the motor out of the burgandy car
Old Feb 6, 2003 | 02:53 PM
Dan W's Avatar
The other side. BTW this car is reportedly very fast.
The other clean way I've seen the single thing done is to use a stock type oil pan and a block hugger on the drivers side... the exhaust exits the block hugger and wraps under the motor in the stock location between the pan and crossmember then goes up instead of back. The drivers side would use something that resembles an manifold flipped upside down. The two pipes would come together into a common collector and place the turbo in about the same location this one is in.
Old Feb 6, 2003 | 06:59 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
The engine above is a 305. In that burgandy Camaro it ran high 9s at around 140 if I recall, supposedly very tame and street driven. Don't know anything about its present level. There was a video of it circulating around here a couple years ago.
Old Feb 6, 2003 | 07:12 PM
Car: Camaro
that looks simpler to fabricate than a twin turbo setup, how are it's street manners? As much as I'd like to run 9s, I'm looking more for a mid 11 second car. Would a single T4 be too small for a 350? How is the clearance in the engine bay for that engine?
Old Feb 7, 2003 | 12:17 AM
89ProchargedROC's Avatar
ya, its a big bore 305 though.
Old Feb 7, 2003 | 12:48 AM
Car: Camaro
would a twin turbo setup be more practical for a daily driver? I found a nice pair of SBC headers that used to be on an L98 Corvette with a T4 twin turbo setup
Old Feb 7, 2003 | 01:32 AM
you have any pics of them?
are they for sale?
are they yours?
Old Feb 7, 2003 | 11:38 AM
Car: Camaro
they are for sale. They look more or less like modified stock headers with T4 flange and wastegate flanges welded on.
Old Feb 7, 2003 | 12:33 PM
ya ok.....i thought they were actually headers
i'd bolt them up to the motor and see if they will work
Old Feb 7, 2003 | 04:03 PM
Car: Camaro
There is a picture of them on an L98 Corvette, I am assuming they would fit.
I also found this turbo kit and a set of grape ape headers on ebay are they any good?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6764
Kit^
http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
Headers^
Old Feb 7, 2003 | 04:12 PM
83 Crossfire TA's Avatar
Block huggers will not clear the crossmember on a 3rd gen...
Old Feb 7, 2003 | 07:48 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Kit^
Headers^
LOL that second system looks mighty familiar dont it?
Old Feb 8, 2003 | 01:39 AM
Dan W's Avatar
Yep, What I should have said here was a stock style DS header thanks.
Old Feb 8, 2003 | 01:42 AM
Car: Camaro
DS header? I probably sound like an idiot, but what does DS stand for?
Old Feb 8, 2003 | 02:48 AM
DS= driver side
block huggers wont clear a STOCK crossmember but will an aftermarket one
no, the grape ape headers wont work
Old Feb 8, 2003 | 07:34 AM
ozzga's Avatar
how come?
Old Feb 8, 2003 | 11:32 AM
Car: Camaro
what if you took a driver side shorty like this one on the right
and put on the passenger side, brought the pipe down and under the oil pan into an upside down, modified block hugger? The block hugger would be the turbo manifold and would be on the driver side. Would that work too?
Old Feb 8, 2003 | 12:48 PM
Originally posted by ozzga
how come?
Measure how much room you've got from the valve cover to the brakes, strut towers... and then take a good look at a set of the grape ape headers and it will be clear, it's not even close. They were designed for 2nd gen engine bays
zerotosixtyV8- well, the driver's side is designed to fit in an f-body, so that's fine. The passenger side... well, that's up to what you do there. I would say that most block huggers will put the collector up to high to fit a turbo large enough to be used as a single. You'll also run into a hassle with down pipe routing if you intend to run a decent size since the recesses to run the exhaust under the engine and chassis are reversed from what would work well for this application
The fact is that most of this trying to hack together existing stuff to work well, well, will end up hacked together and being a PITA and take more time then just building the right thing to start with.
Old Feb 8, 2003 | 01:45 PM
Car: Camaro
What about modifying the stock manifolds into log plenums for a twin turbo setup? I'm exploring options, going for the most cost effective. Almost all the turbo manifolds I see online for sale look like modified stock ones, either off the L98 camaro or corvette.
Old Feb 10, 2003 | 06:42 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
what block hugger header is that in the 3rd last pic ???
Old Feb 10, 2003 | 09:57 AM
It doesn't really matter, he made it fit using a custom K-member...
Old Feb 10, 2003 | 12:10 PM
Guido's Avatar
Car: 2000 Trans Am
They are not purchased block hugger headers. They are totally custom built one off headers. I know the owner and also the shop that built them. Ive spoke with both. They are made from 321 stainless.
They were built and do fit a factory cross member. He has since switched to a tubular cross member.
Old Feb 10, 2003 | 12:12 PM
Guido's Avatar
Car: 2000 Trans Am
Those wont work either. I purchased a set of those thinking that they would work before Ibought mine. They are hooker 1 5/8" super comps arent they? They will NOT fit the cross member.
I like the thought process though.
Old Feb 11, 2003 | 02:58 PM
Car: Camaro
yeah, those are super comps lol. I am trying to visualize it in my head. How about modified L98 Corvette manifolds? Would those work? Flip em upside down and have two T4s up top? or have one up and another down and run a crossover pipe to the otherside and have a T66 there.
Old Feb 11, 2003 | 03:43 PM
Guido's Avatar
Car: 2000 Trans Am
https://www.thirdgen.org/techbb2/sho...hreadid=156342
LOL
Old Feb 11, 2003 | 04:18 PM
Car: Camaro
JoBy said if you cut off the AIR tubes and flip em upside down it should work. Worth a shot, L98 manifolds can be found for only a few dollars.
Old Feb 12, 2003 | 04:43 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
This is modified L98 headers with the flange cut off.
Old Feb 12, 2003 | 11:34 AM
Guido... are you laughing at me?
JoBy, thanks for posting pics of my stuff so I didn't have to. Hell, I've probably posted those a dozen times and people still ask eht same question. This place really should have a 'search' to prevent that...
Yes, they will fit like that, yes, you will have to do some cutting and modifying to clear the brakes and hood (really, the best way would be to hack the collectors completely off and make your own), no, I don't like how they fit so the car won't be leaving my garage like that or with the 2 T3's that I've got sitting around (mostly because I wanted to do something different, too many people have done stuff with them and I was really looking for something a little different then that to start with anyway).
Old Feb 12, 2003 | 02:18 PM
Guido's Avatar
Car: 2000 Trans Am
No I laughed because I found it ironic we were discussing the vette manifolds in that other thread and he asked about it in this one.
*shrug*
No offense meant.
Old Feb 23, 2003 | 01:37 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
this thing is huge Dan, got anymore info about it?
Old Dec 29, 2007 | 07:58 PM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Re: Single Turbo Setup Pictures
i got my blockhuggers to fit on my 3rd-gen i welded 1'' plate on the motor mount brackets.
Old Dec 29, 2007 | 08:01 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
... now that's what I call bringing a thread back from the dead!
Old Dec 30, 2007 | 10:09 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I guess you have strong motor mount brackets now. What does the plate have to do with the headers?
Old Dec 31, 2007 | 09:28 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I'm not for sure what he means, but it might have to do with the fact that block huggers don't fit thirdgens because they hit or exit right on top of the motor mounts.
Old Jan 1, 2008 | 08:06 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Does anybody know whos burgandy car that is??? I really like that and would like to know some specs on it.
Old Jan 2, 2008 | 10:40 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
yea, its more practical.. lol.
http://img411.imageshack.us/img411/7...nturbo2oy2.jpg
Terrell351
Jun 13, 2021 01:13 PM
lt1z350
Aug 28, 2015 05:57 AM
chubsworth
Aug 26, 2015 02:34 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 13, 2015 08:28 PM
