Rear main cap ....yikes
Old Apr 6, 2003 | 08:11 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
This is how it was when I took it off...is this going to be a problem..I hope not because I cant find a new one for the 327...
Engine: 406
another view.....
Old Apr 6, 2003 | 09:19 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
It looks like the oil pan gasket is the only thing that may be affected.
Old Apr 6, 2003 | 09:21 PM
Engine: 406
thats what I was thinking..no cracks or anything else visible
Old Apr 6, 2003 | 09:44 PM
Vader's Avatar
It's only the rear part of the pan seal reatiner. I wouln't lose a lot of sleep over it. Just clean the cap thoroughly, then apply a liberal amount of RTV to help seal and retain the pan gasket/seal. I would avoid trying to weld or repair it, since any distortion of the cap will require machining of the cap and case (align bore/honing).
EDIT: I presume this is a small journal crank?
Old Apr 6, 2003 | 09:54 PM
Engine: 406
Yes it is a small journal...thanks for the reply Vader...I pick up the block this week , and the crank, from the machine shop..all freshened up..I really didnt think it was going to be a problem...but this is my first total rebuild, and I want to do it right the first time..I'm getting quite a few dollars into this project and I didnt want something like this to spoil it....thanks again.
Old Apr 7, 2003 | 05:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looks like somebody set the block down carelessly some time or other.
I agree, nothing serious is affected, only the oil pan gasket rail. That shouldn't create any problems. I wouldn't even do anything any different as far as assembly, than if it was undamaged.
I would certainly not try to swap another cap on there; the crank bores and caps are machined as a set, you will most likely need to have the block align-bored to make another cap fit, not worth going through all that.
Old Apr 7, 2003 | 05:45 AM
ede's Avatar
ede
you might want to have it penetrant or mag tested for cracks, but i doubt it gives you any problems
Old Apr 7, 2003 | 08:30 PM
Engine: 406
glad you all agree on this..thats good enough for me.. Thanks guys for your time..I'm really anxious to get the short-block assembled..The LT1 problems set me back a little on the porting acc. for the heads. But Ive been working a lot of OT to get what I need..No silver spoons here. ..Have a great evening and I'll be talking to ya.
Old Apr 7, 2003 | 09:48 PM
NTChrist's Avatar
Pees me off the way some people in a machine shop will treat blocks/heads, etc. One time when I dropped off a set of heads at a machine shop in Providence, the guy at the front desk threw them 10 feet onto a pallet. I should've taken the heads back, but fortunately them came out unscathed a week later.
Old Apr 7, 2003 | 10:10 PM
Engine: 406
That would have been a tough one for me to swallow..the damage to this cap was done prior to my ownership..the shop I have been using has been very professional....I disassebled the short block myself.
I think at that point I would have loaded up my stuff and gone elsewhere.
Old Apr 7, 2003 | 10:25 PM
ronterry's Avatar
Car: '94 Corvette
I personally would take a little bit of dremal-ing to it. Use the little sanding drums just to smooth it out, & remove any risers that might want to chip off later down the road.
Get that broken edge beveled a little. You’re not going to remove any real material, you just want it smooth.
Ron
Old Apr 7, 2003 | 10:37 PM
Engine: 406
that might not be a bad idea...I'll consider that , thanks Ron. You get my follow-up on the opti?
Old Apr 9, 2003 | 04:15 AM
Engine: 406
Ok..new Question....I got my block and crank back today. Had to go .040 on the rods.....030 mains..and it says thrust std...exactly where is the thrust bearing located on the crank?
in ordering bearings..I dont see a thrust bearing listed with the kits..I'm ordering this kit from northern autoparts (rering kit)...http://www.northernautoparts.com/Pro...?ProductId=525
Will the thrust bearing be included with the rering kit, or is that something I need to order seperate..I dont see a listing at any suppliers..Nor do I remember removing anything other than the bearings under the caps..I dont know what a thrust bearing looks like..maybe that was the partticals in my pan after-all..help me out..here.. (duh)
Old Apr 9, 2003 | 04:19 AM
Engine: 406
pan particals pic...https://www.thirdgen.org/techbb2/sho...hreadid=168614
Old Apr 9, 2003 | 04:58 AM
Engine: 406
ok I'm getting this I think...thrust is the flanged part of the bearing, right...so the main size is the size I am concerned with since the thrust was left standard..correct me if I'm wrong....gosh this is fun!
What do you think the chances of this motor running when I'm done are..LOL
Old Apr 9, 2003 | 12:17 PM
Vader's Avatar
Riley,
Yes, thrust is controlled on teh #5 main bearing. If the thrust is STD, that means that no material had to be machined/ploished from the crank to clean up the thrust surfaces. Make sure your replacement bearings are sizes accordingly, with 0.030" undersize and standard thrust width. Clevite or TRW should be able to accomodate you easily.
You'll get it running, I'm sure.
Old Apr 9, 2003 | 02:34 PM
82camaro's Avatar
Car: 82 camaro SC
"I personally would take a little bit of dremal-ing to it. Use the little sanding drums just to smooth it out, & remove any risers that might want to chip off later down the road.
Get that broken edge beveled a little. You’re not going to remove any real material, you just want it smooth."
I agree, smooth it up a little
Old Apr 9, 2003 | 10:25 PM
Engine: 406
Thanks for the reply Vader.. the bottom end of the engine is new territory to me..so much to learn. i'll get it. Thanks for the support! I'll be talking to ya.
82 Camaro...I'm going to smooth the journal out a bit . thanks for your input!
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
