My thoughts on the G Force Trans...
Old Jul 15, 2003 | 05:07 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Except for the slightly noisier gears, I'm lovin this tranny.
How about 1800 RPM's at 65 MPH in fifth?? 2000 RPM's at 70 MPH??
And that's with 3.73:1 rear gears!!! The .59 ratio 5th makes a world of difference!
No "special" tranny mount, speedo alteration, etc... required.
And the first 4 gears are still nice and low....but it sounds weird when going from forth into fifth if you don't wind out forth quite a bit 1st....
Oh and BTW, I'd recommend the Pro-5.0.....makes a world of difference!
Old Jul 15, 2003 | 09:06 PM
BrianI's Avatar
What are 1-4 ratios?
Old Jul 16, 2003 | 12:51 AM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Taken from their website....."2.94, 1.94, 1.34, 1.00 ratios in gears 1 thru 4"
Old Jul 16, 2003 | 11:13 AM
BrianI's Avatar
Old Jul 16, 2003 | 11:46 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Glad to hear that you're happy :P
How much more "noise" is in the gears and are you comparing it to the stock t-5?
Old Jul 16, 2003 | 11:48 PM
Confuzed1's Avatar
Car: 83Z28 HO
Yeah, I'm comparing to a stock T-5. That's the only other trans I've had in the car....just makes a little more noise even with the synchro trans.... (like I have), cause the gears are not cut as steep of an angle like the stock gears. That's how they're able to rate it at a higher torque/HP than a stock trans.
Old Jul 17, 2003 | 09:23 AM
Fevre's Avatar
Car: 89 Formula
A louder exhaust and/or stereo will take care of that.
I am going this route with the t-5 I am putting in my vette.
Old Jul 17, 2003 | 11:42 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Your a great salesman!
Also, what clutch are you using?
Old Jul 18, 2003 | 12:01 AM
Confuzed1's Avatar
Car: 83Z28 HO
I'm flattered I guess...
Hey, seriously though, so far I'm happy with it overall. The "Jury's still out" so far as how long it will last. Remember - I just installed this like maybe 175 miles ago!!!
By no means am I trying to sell anything. If it blows up next week, and I post about it here - then maybe I can save someone else from getting screwed.
The whining still concerns me a little though, But they say that's "normal".
BTW, I'm just running a standard clutch.
Old Jul 18, 2003 | 12:36 PM
Confuzed1's Avatar
Car: 83Z28 HO
Trust me, they don't make an exhaust too much louder....(see sig).
But I do need a louder stereo.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
tyeo098
Nov 30, 2015 06:27 PM
earlpote
Sep 12, 2015 11:55 AM
IROCZ1989
Sep 4, 2015 11:54 AM
