billet disc = rag joint eliminator
Old Sep 7, 2003 | 01:52 AM
logikal6785's Avatar
my rag joint is shot, it seperates before doing its turning, leading to like 15* of play in the steering wheel before the turn begins. Anyway I want to get a billet rag joint eliminator. I figure if i take in my joint and have a piece of billet aluminum or even just some cast iron cut to the same diameter I can drill out where the holes go. Then i can install that piece at the end of the steering shaft and it will connect the shaft to the box ... it means i'll have a little more vibration in the steering wheel, but increased road feel and it can never have sloppy steering again. one less thing to fix in the future =) If you guys see any problems, have done this before, or have pointers, pls respond. thx guys =D
Old Sep 7, 2003 | 11:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: billet disc = rag joint eliminator
Like this (see pic):
RBob.
Old Sep 7, 2003 | 02:49 PM
can you please please post the specs for that eliminator ? what you made it from, the sizes and where to drill the holes, what did you drill it with, and if you had it made what did it cost ? thanks man =)
Old Sep 7, 2003 | 04:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The disk is mild steel 1/4" thick. It is 2.57" in diameter. I used the original rivets and placed the holes in the original locations. One set of rivets are peened into chamfered holes (see this pic).
The other set of rivets were then welded to the disk. Need not be a full weld as there is no pressure pulling the rivets out.
RBob.
Old Sep 7, 2003 | 04:44 PM
thanks so much man =)
Old Sep 7, 2003 | 06:22 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Or there is always Borgeson joints-
http://www.borgeson.com/steeringcolumns.htm
I have never done one on a late model car, Only on my '68 Vette. Sent the entire old shaft to them and they duplicated it. This was probably 8 years back.
Old Sep 8, 2003 | 06:36 AM
89_3rd_gen's Avatar
Some advice:
Using a universal or the solid disc will need the use of a slip type steering shaft. Remember the rag joint will handle a 3 axis missalignment. The other two couplers can not without binding.
I bought my slipper shaft and universal at Flaming River. The new shaft gave more header (SLP) room too.
http://www.unbalancedengineering.com/
Old Jul 1, 2004 | 01:45 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Bringing it back from the dead...
RBob, hows everything holding up with the solid disc in place of the rag joint?
I did this a few years ago and Ive always been afraid that with the camaros rubberized-body construction that possible bending moments from chassis flex might damage teh steering gear or jsut plain snap the input shaft clear off...
Anyone ever replace it with a u-joint? Ive been thinking about possibly trying to adapt one to a stock steering shaft to safely replace the rag joint.
Old Sep 8, 2005 | 03:12 PM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
I'm also curious about this. I'm very tempted to take the easy route and just replace the rubber with the solid piece (I assume the 4th gen unbalanced engineering eliminator will fit)
Old Sep 8, 2005 | 03:50 PM
CaysE's Avatar
I'm interested in those borgeson pieces. Anyone have experience with them?
Old Sep 8, 2005 | 04:29 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Does anyone have the specs on what the spline count, and size we need for our cars is?
Coleman sells many diffrent style steering joints, from alum, to steel, with needle bearings, etc.
http://www.colemanracing.com/catalog...hp?cPath=2_114
Old Sep 9, 2005 | 01:24 PM
SweetRide45's Avatar
If anyone knows the sizes, etc. offhand, I'd like to know as well. I might be possibly changing the shaft and joint when I do the new drive train and box swap. The Flaming River ones look nice, but not sure on what to get....
Old Sep 11, 2005 | 12:13 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Posted this long ago(been on car over 2 years,0 problems,NO play,very solid & smooth)Astro van U-joints w/camaro steering shaft.Still colapses,plus the lower joint has a vibration dampner built in.There is also a real bearing on the cloumn(from astro) out of the firewall.Instead of the plastic bushing the camaro uses.Spent a whopping $6 for the astro van shaft.
Old Sep 11, 2005 | 12:17 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Upper Joint.U-joint ends match exactly from astro to camaro.Same # of splines & double D shaped hole on upper joint.
Old Sep 11, 2005 | 01:12 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
any particular year? 2wd or awd? v6 or v8 if that matters?
Old Sep 11, 2005 | 01:16 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Im almost 100% sure ALL astro vans use a u-joint shaft & the bearing(in the steering tube coming out from the firewall).No matter the model.Non are V8s though.
Old Sep 11, 2005 | 11:17 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
I think replacing your rag joint with a solid disc is a bad idea. The steering shaft does not align perfectly with the steering gear (steering box). That would cause bind. You are much better off replace the rag joint with a new one or finding a universal joint that will work.
Old Sep 12, 2005 | 07:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is already a U-joint in that shaft. The solid disk works without issue. Only downside is that hydraulic noise is now transmitted through to the interior of the vehicle. Was spooky at first, but I got used to it quickly.
The upside is that the steering is more responsive and precise.
RBob.
Old Sep 12, 2005 | 08:30 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
84 1LE.
Do you still have that car? Anyway you could rotate the shaft for us and see if its stamped with a part number?
What would I call that part if I was to call GM or a junkyard n ask for it?
I like this idea, great find !!
Old Sep 12, 2005 | 12:37 PM
RBob, I see you built your own from scratch...
Has anyone tried the unbalanced engineering disk? Looks like it's the same, but since it's for a 4th gen I dunno.
Old Sep 12, 2005 | 01:27 PM
Dewey316's Avatar
Car: 1990 Camaro RS
IIRC, When I talked with Jason at UE, he indicated it did not work for thirdgens. I'll try to find the info, or I'll ask him about it again.
--John
Old Sep 12, 2005 | 04:02 PM
Dewey316's Avatar
Car: 1990 Camaro RS
FYI. I asked Jason about this again.
No it won't [fit]. We plan to release one for the 3rd gens at some point, but just haven't had the time to complete the project.
Jason S.
Old Sep 12, 2005 | 05:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Was the Astro van shaft the same length? I snagged one in the spring when I had to relocate my column over and the f-body upper coupler was still too big to clear the headers. I saw the Astro van used u-joints and the upper double D and lower steering box size was the same. I chopped off the yokes and welded them onto my steering shaft before measuring the length. If they're the same length, it would have been a lot easier to just swap complete shafts.
Old Sep 12, 2005 | 05:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Old Sep 12, 2005 | 06:35 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Originally posted by Dale
84 1LE.
Yes i still have it(16 years now).Ive got a couple of these astro van shafts.None have a part # though.I would call this a "steering shaft w/U-joints)".As for buying id go to the junkyard(paid $3 for mine at the J.K)Dealer probably want a small fortune.
Old Sep 12, 2005 | 06:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The Astro van steering shaft is SHORTER than the 3rd gens.The ONLY parts i used from my original is the actual telescoping shafts,flat per-load spring(inside the big u-joint),rubber boot.I had to shorten my original shaft by about 1.5 inches so it would colapse as much as the stock f-body unit.I pressed the small U-joint out of the astro shaft after grinding off the splayed end.The steering shaft slides out from the big u-joint- AFTER you press out the bearing caps so the cross & the doulble D end are still attached,but are apart from the other half of the joint(which will still be on the shaft).Push the shaft out past the U-joint.Then grind down the small stop(bump) near the end of the shaft.ALSO i decide to use the 4TH GENS DOUBLE D end.Because the bolt is a pass thru type.As apposed the the astro's.Which clamps the outter part of the U-joint.Theres more,but i wont get into now.Too much to type.
Old Sep 15, 2005 | 08:02 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Stephen 87 What is that master cylinder from?? I have been looking for one where the lines exit towards the driver side.
Kevin
Old Sep 15, 2005 | 08:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Just about any GM other than a third gen exits on the fender side.
It's a manual brake master cylinder from an S10. Notice the adapter fittings to put double flare brake lines into a metric bubble flare fitting.
I also moved the brake lines to the inside of the steering shaft to keep them away from the headers.
Old Sep 16, 2005 | 09:42 AM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
It's called an intermediate steering shaft.
I'm not much of a fan of the idea of replacing the rag joint with a solid disk. The steering shaft and steering box aren't perfectly aligned, plus the steering box does move around (due to frame rail flex) during aggressive turning conditions. Also add body flex into the equation, and you will be inducing bending loads in all these steering components, which is not a good thing. Put a U-joint in instead, and you'll eliminate any slop and won't bind anything up.
Old Sep 16, 2005 | 10:03 AM
Dale's Avatar
Engine: 350 S-TPI
Thanks, looked it up and gm wants over 100 bux for it.
Since it will have to get cut, I'll find a used astro shaft, and used camaro shaft. Keep my stocker as backup.
Now time to find a saturday morning free to go hunt
Old Nov 2, 2005 | 11:53 AM
cwalsh's Avatar
Car: 2004 Corvette
how big was teh hole drilled into the middle of the disc? It looks like 3/4"??
Old Nov 3, 2005 | 06:37 PM
JPrevost's Avatar
Car: 91 Red Sled
Mike, there is no need to worry about bending loads... the end nearest to the firewall is a CV joint, not a ridged u-joint. CV joints allow for LOTS of movement and are almost always designed to move in and out a small amount.
The solid rag joint is awesome, I've tried it and I loved it... then I went with an astro-thirdgen-astro shaft and kept the astro's rubber insolator (not a rag joint). Feels even better
Old Nov 11, 2005 | 05:52 PM
Cyfun's Avatar
Car: '83 Trans Am, Black on Red
Engine: LG4 305ci V8 w/ CCC-Qjet
Transmission: Rebuilt 700r4
Axle/Gears: 4th gen 2.37 posi w/disc brakes
The newer fullsize Astro vans have a steering shaft that bolts in perfectly without any length issues. The only problem I ran into is that my steering wheel is off 90 degrees. I'm sure if I could get the wheel off, I could rotate it on the spline, but the wheel is this Dino leather wheel that doesn't work with the normal wheel remover tools or wheel pullers. :^/
Old Nov 11, 2005 | 06:07 PM
JPrevost's Avatar
Car: 91 Red Sled
Do you mean the Chevy Express vans? They don't make full size Astro vans, Astro was mid size .
If you ment full size Express... got any pictures? If I were you I wouldn't just remove the wheel and reclock it. Your signal indicators won't work correctly. Best way is to remove the U-joints and clock them "incorrectly". The only time having them clocked wrong is a problem is for velocity sinking.
Old Nov 11, 2005 | 08:01 PM
Cyfun's Avatar
I don't recall exactly what it was, but my old post just says '97 Astro.
Old Nov 11, 2005 | 08:24 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The last astro i saw was a late 90s(dont remember the yr),but the shaft didnt look any longer than the other astros.BTW i think GM stoped making them already.Also the splined shaft for the steering wheel has the splines spaced apart differently,they are not all indentical.This way the hub only goes on one way.Simply rotaing your wheel will not correct your problem.
Old Nov 12, 2005 | 08:45 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Axle/Gears: 2.73 Posi w/Disc
Stephen 87 IROC,
I see your headers are AIR equipped, but most of the holes are plugged. If the line coming from Cylinder #1 for EGT measurements?
Old Dec 3, 2005 | 12:50 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Those are big block headers, they dont come with air.
Most likley each port is for individual EGT.
Old Apr 16, 2007 | 09:52 AM
AlkyIROC's Avatar
Car: 87 IROC L98
LOL! Redirected back to this thread from a newer one asking about eliminating the rag joint Sorry for the late reply.
Those are not AIR ports in the headers. They are EGT ports. I only have a single EGT probe. If I had a real data recorder, I'd put EGT probes in the the tubes.
Old Apr 17, 2007 | 08:28 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Stephen87IROC, That sure looks good...Have you had any problem with the steering shaft yet???? Am considering some way of getting rid of that rag joint... Thanks, Tom
KO1
16
Oct 15, 2015 05:00 PM
sjorgens
Oct 1, 2015 07:54 PM
