$4D ecu file now available...
Old Nov 16, 2003 | 02:50 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Ok... heres the file. It has all the info i could find thus far. Im sure most of the stuff ive found is correct but i have yet to test anything to see if the address' are correct. Anyway, here it is. Oh, thanks to Jon for lending me his 8746 ecu file to use in conjunction with the 7747 hac and everyone else who helped enlighten me along the way.
8063.ECU
8063_IAC.ECU
Old Nov 16, 2003 | 02:52 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Old Nov 16, 2003 | 04:49 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Old Nov 18, 2003 | 05:44 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
rename it to a .bmp and tell people to rename it after download
Old Nov 25, 2003 | 10:59 PM
Car: 88 Camaro SC
Engine: SFI'd 350
ttt
Old Nov 26, 2003 | 03:09 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Yes! :hail:
If you want to host this off AOL, let me know and I'll set you up with a ftp account..
Found a one insanely minor bug so far, I'll PM you a full list after I've had time to nitpick (or just fix them all and send you the full list with fixed ecu)
Old Dec 5, 2003 | 09:20 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Alright, got tired of toggling between tuner cats and TunerPro so I made a tdf from scratch using all the info i collected so far. So, for all of the one other 8063 users out there heres my expanded 8063 tdf for tuner cats.
MyTDF.zip
Old Dec 21, 2003 | 10:44 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Update: Added an add-on ECU as well as TDF file (in MyTDF.zip) with the advanced iac stuff like the throttle follower parameters. That should be good enough for now...
Old Jan 2, 2004 | 02:40 PM
Z28GEN3's Avatar
what prgram did you use too write that?, i cannot open it.
Old Jan 2, 2004 | 04:49 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I used the tuner cats tuner definition file editor/creator that I got. The tdf is meant for use with the Tuner C.A.T.S. software package, as opposed to the universal ECU's for the freeware packages. What errors are you having when you try to open it in tuner cats?
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
MitcherNeaf
DIY PROM
Sep 24, 2015 09:23 PM
