L98 Ported head/cam Hotcam Stock tune Dyno numbers
Old Dec 30, 2003 | 01:26 AM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
I went and dynoed today. Stock runners, stock ported and siamesed base, stock injectors, stock programming, stock ported heads, headers, stock L98 bottom end with 106K on the clock.
288.4rwhp
351.4rwtq
Whatcha think?
Old Dec 30, 2003 | 08:53 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Doesn't sound to bad without tuning. Do you have the A/F ratio readout from the dyno run to see just where your tune is at?
Old Dec 30, 2003 | 09:18 AM
Car: 92Z28
Transmission: A4
It was rich towards the bottom and ideal towards the mid/high range with 45psi fuel pressure.
Old Dec 30, 2003 | 09:45 AM
bnoon's Avatar
That sounds about right. Larger cams need the VE (speed density) or MAF transfer CFM-to-voltage ratio lowered in the idle-to-low RPM areas until the engine comes "on cam". Sounds like it shouldn't be to hard to tune in some more low end throttle response for the new combo. Good job!
Old Dec 30, 2003 | 05:04 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Very nice numbers!
Old Dec 30, 2003 | 06:59 PM
MdFormula350's Avatar
got to love torque
Old Dec 30, 2003 | 07:59 PM
smithtc's Avatar
How about some more numbers to get an idea of what the overall curve looks like? Rpms?
Those are great numbers for a basically stock engine. Think you can get 12s off of that?
Old Dec 30, 2003 | 09:25 PM
Car: 92Z28
Transmission: A4
The peek hp number was a TPI limited 4400rpm on hp,although it carried over 275rwhp through 5300rpm. The torque peeks around 3900rpm and stays over 325lbft from 2600 through 4600rpm.
The timing and fuel curve was killing it on top too. I am sure it will carry out a little further with a good tune.
I am hopefull it will go 12.9s with a good launch as it sits and go considerably faster with an optimal tune.
Thank you for the compliments everyone.
Old Dec 31, 2003 | 01:00 AM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
Dude, I am very interested in seeing if you run 12's with that combo. Cause, I have alittle bit more work done and I havent run my car yet. I hope you break 12's bud. Good luck!
Old Dec 31, 2003 | 11:23 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I hope you break the 12's to bud because I have alot more done. If you it 12's with that combo I'm gauranteed 12's with mine. Good luck and keep us posted!
Old Dec 31, 2003 | 05:48 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Congrats those are great numbers. I only wish my car had done as well.
Old Dec 31, 2003 | 10:41 PM
Car: 92Z28
Transmission: A4
Thanks guys. I am pretty pleased with it so far. We'll see what the track proves.
Good luck to all and happy new year!
Old Jan 1, 2004 | 11:26 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I have Corvette heads, and SLP 1 3/4" headers with a T56, so that gives you a similar baseline to compare your numbers too.
Old Jan 2, 2004 | 09:29 AM
Car: 92Z28
Transmission: A4
What runners were you running on that run?
I really like your car and it is actually one of the reasons I took on this project. I just wanted to run with the LS1s at the track with a tpi.
Old Jan 3, 2004 | 04:10 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
He had TPIS large tube runners when he dynoed, and ran the 12.80 number. Now he has the SLP fully siamesed runners but no track times or dyno numbers yet.
Old Jan 6, 2004 | 02:27 PM
QuickGlass's Avatar
After seeing your results from the siamese mod, I was thinking of doing the same thing. 288HP at 4400 RPM is really good without spending a fortune on an intake.
Can you please give me your horsepower numbers at some rpm points so I can see the shape of the curve.
RPM
2000
2500
3000
3500
4000
4500
5000
5500
Old Jan 8, 2004 | 02:34 AM
Car: 92Z28
Transmission: A4
RPM
2000
2500
3000
3500
4000
4500
5000
5500
I really couldn't tell much from the lower RPM range since it is an auto. It just shifts down to 2nd until around 3500rpm.
RPM TQ HP
2000-
2500
3000
3500-340-230
4000-350-260
4500-340-288
5000-295-280
5500-235-260
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
