Visual differences between 305 tpi and 350 tpi
Old Jun 9, 2004 | 06:09 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
hi i was wondering what are some easy visual differnces to spot between a 305 tpi and a 350 tpi
some pictures would help
i did a quick search on the topic didnt find anything
thanks in advanced
Old Jun 9, 2004 | 06:50 PM
ede's Avatar
ede
350 has a 4" bore, 305 is around 1/8" smaller, other than that they look the same
Old Jun 9, 2004 | 06:51 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If you're asking about the differences between induction systems between the 305 and 350, there are none. The only difference is the injectors and computer..
Old Jun 9, 2004 | 07:33 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
just pop the hood look at the engine and being able to tell them apart
Old Jun 9, 2004 | 07:38 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Am I correct in assuming that you are talking about TPI motors?
If so, then no, they look the same.
The very first place you should look is the VIN number.
If the 8th digit is an “F”, then it’s a 305.
If it’s an “8”, then it’s a 350.
If it’s an “E”, then it’s a 305 throttle body injection.
Scott
Old Jun 10, 2004 | 03:53 PM
DonP's Avatar
Car: 1990 GTA Black/Black lthr
Engine: 305 TPI stock
Scott
Assuming the motor wasn't replaced...
Old Jun 10, 2004 | 04:20 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If the Vin has the letter F for a 305 and someone tells you its been replaced with a 350 from a corvette, just run and don't worry about the visual details.
Old Jun 10, 2004 | 06:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Unless you look at the casting number, there is no concrete way of determining whether it is a 350 or 305.
Unless, as stated, it is the original engine.
Old Jun 10, 2004 | 08:02 PM
Iroc87-355's Avatar
Car: 1987 IROC Z
Engine: Corvette 355ci
so basically you have to take the engine apart to see if it's a 305 or 350 ?? Is the fireing order the same ??
Old Jun 10, 2004 | 08:09 PM
DJP87Z28's Avatar
You could look at your 355 ci Corvette engine in your 87 Iroc for any differences.
Old Jun 10, 2004 | 11:17 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
No you get the casting number and have a print out of the Mortec list in your back pocket. Works wonders.
Old Jun 10, 2004 | 11:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
you can also write it down on your arm (if you're like me, your hand is to covered in oil/dirt/grease to write anything on) and go home and look it up online.
Old Jun 11, 2004 | 12:08 AM
Iroc87-355's Avatar
Car: 1987 IROC Z
well actually I found an eaiser way, if you look behind the block by the distrib on the drivers side, it'll tell you the size of the motor.
Old Jun 11, 2004 | 12:17 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
GM never stamped the engine size on the block (well, they DID, just not there). The area you refered to is where the casting number is as well as the date stamping and what not.
Old Jun 11, 2004 | 05:04 PM
thirdgen88's Avatar
Car: 1995 Corvette
Yeah, actually they did stamp the engine size there on the one-piece main blocks..
Old Jun 11, 2004 | 05:15 PM
Iroc87-355's Avatar
Car: 1987 IROC Z
yep there you go, that's where I saw how big mine was
Old Jun 14, 2004 | 08:08 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Just for the searchers. Not all one pc blocks had the size stamped or that casting configuration.
You can read more at Mortec. HTH someone.
Old Jun 15, 2004 | 01:08 AM
TestyAmoeba's Avatar
Car: 1989 Firebird Formula
Engine: TPI 350 Vette motor
Transmission: 4spd Auto
Heh..sounds like the Formula I am buying from a friend.. Originally came with the 305 TPI and had it swapped out for a 350 TPI from a Vette..
Nate -
Old Jun 7, 2021 | 03:21 PM
Butch Brooks's Avatar
Car: Custom built Trike
Axle/Gears: 12bolt c-10
Re: Visual differences between 305 tpi and 350 tpi
Scott
no vin number installing into trike.
Old Jun 7, 2021 | 07:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
17 year old thread
Unless the block has been decked, there's still a partial VIN and a Suffix code stamped in the block at the front of the passenger side head. There will also be a casting number on top of the bellhousing at the back of the block.
Old Jun 8, 2021 | 09:58 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Can remove 1 valve cover and read the cylinder head casting number.. 081 or 4416 is a 305 motor.
083 or 217 is a L98 350 TPI motor.
Wade787b
Sep 29, 2015 01:15 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
