did some wetsanding and bufing today
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
decided i didn;t like the way the hood looked on the car so i wetsanded again with 1500 and then buffed with sure finish. now my louvers look like crap all old and stuff so i found a new gm set on ebay to replace them. tires should be here this coming week so i can finally get it off the stands and see how it loks all together.
Engine: 305 tpi LB9
one more view.. i am going to wetsand the entire car again less the hood and nose that i did today.
pics in tha garage is not the best, but i will get some outdoor pics next week..i hope
Engine: 305 tpi LB9
thanks
i'm near springfield....wet sanding is not hard just alot of elbow grease. even buffing is easy if you use a slow cut product. sure finish that i use is very fine so it allows me to go over and over without a worry of burning the paint.
Jeff
Jeff
Engine: L98, Hemi 6.2
Originally posted by JeffW
thanks
Jeff
thanks
Jeff
Engine: 305 tpi LB9
house of color cobalt candy blue, there is a gm blue that is also close to the same shade.
jeff
jeff
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
ain't sandpaper great? That's the difference between an everyday paint job..and a custom paint job
Engine: 305 tpi LB9
sellmanb that area is black from the factory, so it will be black when i'm done, thats where the wipers and the grate for the air intake is. yes the engine bay is painted to match the car.
jeff
jeff
Car: Take
Engine: Your
Transmission: Pick
sellmanb that area is black from the factory, so it will be black when i'm done, thats where the wipers and the grate for the air intake is. jeff
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
That looks great man. Someday I wanna do the same to mine. What kind of buffer do you use and with what kind of pad?
Hi GMTech!
So, you own a 20th TTA too?
Great!
Are you on the TTA maillist? What name do you go by?
Just wondering if you know what your car number is, and what options and milage.
You have a nice collection going!
Another TTA owner,
George
Great!
Another TTA owner,
George
Car: Take
Engine: Your
Transmission: Pick
Originally posted by Mr. TurboTA
Hi GMTech!
Great!
Another TTA owner,
George
Hi GMTech!
Great!
Another TTA owner,
George
You can see his progress here:
http://63.99.108.154/ubb/ultimatebb....c;f=4;t=000401
http://63.99.108.154/ubb/ultimatebb....c;f=4;t=000406
http://63.99.108.154/ubb/ultimatebb....c;f=4;t=000419
Originally posted by GMTech
Do you know which cars were supposed to be black and which body color? Of all the cars at my house (87 GTA, 89 TTA, 87 TA, 91 TA Vert & 92 TA Vert) only the 87 TA has a black cowl, but the car itself if black. The only reason I mention it as not being body color is because it looks like smooth undercoating of some sort instead of regular paint like the other 4 got. Any idea???
look at the vin for n...i think the norwood cars got the body color cowl ir vice versa...i saw a norwood 89 with the body color cowl while my van nuys car had the black color but it was black also
Engine: 305 tpi LB9
metalic i use a makita buffer with a 6" wool pad with sure finish compound its a liquid. i also have an orage pad that sure finish makes but it seems to put more scratch in the car than it takes out. i bought them both from the autobody store.com. they have some great deals on this type of stuff. i think the entire mikita package with bag two pads and buffer was like 180.00. it has a great varible speed and a slow ramp up start very easy to use and forgiving as you control the speed.
Jeff
Here are the results for your query on: *********fn150096
Made in: United States
Manufacturer: General Motors
Make: Chevrolet
Carline Code: F-Body
Carline Series: Sport Coupe, Z28
Body Type: 2 door coupe
Engine Code: 305 ci V8 LB9 (1985-1986)
4 is the CHECK DIGIT.
Model Year: 1985
Assembly Plant: Norwood
Production Sequence: 150096
Hi GMTech,
Sorry. I thought you owned the car!
It's always great to see people helping out others with their cars!
Hopefully it'll be on the road soon!
George
George
Car: Take
Engine: Your
Transmission: Pick
George, Yeah, I just said it was at my house. I tried to get him to come off it, but he wouldn't budge.
Jeff, yes, POR15 is a better description of what it looks like, and my car in question is a Norwood car. I'll have to look at the GTA and see if its a Van Nuys car since its also an '87 but has a red cowl.
-Just confirmed that the body colored cowl is a Van Nuys car.
So in theory, Norwood cars got black cowls and Van Nuys cars got body colored cowls. Hmmmm
Engine: 305 tpi LB9
ok how about a/c or the vents would that have anything to do with it? maybe its just completly random...
jeff
jeff
And thats why it was just a theory. So who can figure out the real story behind black -vs- body colored cowls???
Also may have been a year by year thing they did.
