Which third gens don't have a power steering cooler?
Old Dec 31, 2004 | 04:39 PM
25THRSS's Avatar
Which year third gens do not have a power steering cooler stock? How were the lines ran, and do you have any pics? Here is a picture for reference.
https://www.thirdgen.org/techbb2/sho...teering+cooler
Old Dec 31, 2004 | 04:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
I thought they all did.
Old Dec 31, 2004 | 10:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't remember my original V6 having it.
But, after 5 years, the memories are fading.
Old Dec 31, 2004 | 11:54 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
my 85 ta doesnt
im adding a real one this weekend anyways
Old Dec 31, 2004 | 11:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I don't recall my 82 having one. But hell, it probably burnt up.
Old Jan 1, 2005 | 12:33 AM
25THRSS's Avatar
Anybody have any pics without the cooler?
Old Jan 1, 2005 | 12:45 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
What angle, where, etc? I may have some saved, if not, I'm going to my car later this morning and can grab some.
Old Jan 1, 2005 | 12:55 AM
25THRSS's Avatar
That would be great! I just want to see how all the lines connect. Do they simply go from the resevoir to the pump and back without the loop involved? Some pics showing the area similar to the top picture in the link would help me out a lot. I would really appreciate it, thanks!!!
Old Jan 4, 2005 | 04:02 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
My 83 V6 Camaro didn't have it; the 84 Z28 didn't have it; the 86 V6 Firebird SE did have one; and I dunno if the 89 Formula did or not, as the steering box was MIA when I got the car.
It's basically a length of hardline that runs across under the radiator and back in the return line to the pump.
Pete
Old Jan 5, 2005 | 12:04 AM
Apeiron's Avatar
Engine: 383 Carb
Interesting, my 84 Z28 does.
Old Jan 5, 2005 | 12:07 AM
25THRSS's Avatar
Anyone with a serpentine setup not have one?
Old Jan 5, 2005 | 12:10 AM
EvilCartman's Avatar
Car: '82 Z28
My 82 doesn't have a cooler, didn't even know such a thing came on these cars
Old Jan 5, 2005 | 04:22 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
My 84 LG4 T/A doesn't have one. My friends 87 LG4 Camaro IROC does. I think in 84 the L69 5.0L HO cars got them. I imagine TPI cars got them too.
Its basically a metal pipe mounted under the radiator with standard line clips. The lower pressure return line comes off the steering box, goes under the radiator and loops back, and then goes into the power steering pump return fitting.
Old Jan 5, 2005 | 07:09 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Most if not all will have a cooling loop (GM calls it a long return line,) Aftermarket coolers are basically small radiators. Like this one: P/S pump fluid Cooler
Old Jan 6, 2005 | 09:35 PM
Apeiron's Avatar
Engine: 383 Carb
Mine was an LG4.
Old Jan 7, 2005 | 08:16 AM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Same here...
Old Jan 7, 2005 | 03:26 PM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
My '91 Z's got it..... I think it came on all cars with the quick ratio steering, as that will heat up the hydraulic fluid in the system, hence it would need cooled down. Should be on most performance optioned cars. I don't think I have ever seen one on a V6 car.
PS.... I have it on both of my '87's....the IROC and the Z..
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
InfinityShade
Aug 22, 2015 08:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
