NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
update on car
Old Jan 1, 2005 | 11:27 PM
novadk13's Avatar
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
update on car (suspension is now done)
Began the suspension tonight on the 92 firebird, links to the the car is in my sig
The panhard rod starts to be removed
The panhard is out in this pic, removed rather easy since most of my bolts were not that rusted
Removed the sway bar the cordless sawzawl came in handy again. The stock sway bar and panhard verse the old stuff little better I would say.
The lower control arms are getting removed, damn thing fell out breaking the cheap plastic craftsman shop light it still works so I guess its not that bad.
The new lower control arm compared to the stock stamped steal piece
Lower control arms in place
Pic of the stuff installed
another from under
Nothing is torque down yet im just gonna do them all at once, still have to install the torque arm, front sway bars, wonder bar, B&G sport comp springs, and bilstein shocks and struts gonna do a brake job while its all apart and repack the bearings. Need to buy some more tools, need a torque wrench
Old Jan 2, 2005 | 12:49 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Hey,looks good.I would have gone with black innstead of red but it looks good anyway.Keep us posted.
Old Jan 2, 2005 | 01:15 AM
novadk13's Avatar
For the front springs my haynes manual says you need to remove the pivot bolts to remove the springs so basically remove the whole lower control arm, no other way?
Old Jan 2, 2005 | 12:15 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
no, just make sure the car is high enough that you can let the arm swing down. put the jack under the control arm, then remove the strut and spindle. the SLOWLY lower the control arm, its a good idea to wrap a chain around the spring so it doesnt go anywhere, and stand off to the side, kinda like playing with a loaded gun
Old Jan 2, 2005 | 04:37 PM
novadk13's Avatar
Shocks and springs out
The stock out, bilsteins going in
Shocks and springs in just need to get a torque wrench and a 21mm socket and Im almost done in the rear all I will need to do is adjust the panhard so that each side has the same amount of tire sticking out.
Old Jan 2, 2005 | 04:42 PM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
Looks rea familiar to a certain Formula 350(lol) that I know of now :-) Forget a brake job and do the LS1 swap. It;s easy and pretty cheap to do ...........Besides it looks better and fills the rim up wiht brakes :-)
later
Jeremy
Old Jan 3, 2005 | 09:32 PM
RockinGTA89's Avatar
Car: 1989 GTA Trans sold :(
Engine: 350 TPI L98 (B2L)
Transmission: TH700 R-4
keep up the good work dave!
looking good..
you should try to sell your non adjustable panhard bar on the boards? or somewhere in the classifieds..
let me know when you planning installing that torque arm..
i wanna view this first hand and see how it's done when i do mine
Old Jan 3, 2005 | 10:33 PM
novadk13's Avatar
Yeah I need to post the panhard since I dont need it, Got the sway bar in and torqued down all the bolts allt thats left in back is adjusting the panhard what size are the 2 bolts on the struts is that a 23mm?
Old Jan 3, 2005 | 11:12 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
looking good so far buddy.
Old Jan 3, 2005 | 11:31 PM
novadk13's Avatar
thanks, this is the first big mod that I have done myself so Im a bit excited about it lots of trips to sears for tools, looks like I need a 23mm wrench for the strut bolts. I just hope I can get the torque arm angle correct
Old Jan 9, 2005 | 09:54 PM
novadk13's Avatar
Everything off down to the spindles
Stock spring out
New Bilstein strut in and the new spring in
All in back together
Old Jan 10, 2005 | 08:06 AM
3.8TransAM's Avatar
Shoulda done the brake swap while u were there :-)
Woulda been easy and they look real big lol
later
Jeremy
Old Jan 10, 2005 | 05:07 PM
novadk13's Avatar
later
Jeremy
I can still do it, I'll see how my funding is the end of next month.
Old Jan 10, 2005 | 11:16 PM
novadk13's Avatar
The stock stuff is out
The new wonder bar and front sway bar
The new stuff in hopefully handle as well as I think it will, all thats left is the torque arm and SFC's
Old Jan 11, 2005 | 01:06 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
lookin good. youre well on the way to a handling beast. i might be looking to sell my ls1 calipers/carriers/ and brackets if youre interested
Old Jan 11, 2005 | 08:52 AM
3.8TransAM's Avatar
how much $$$$ Kag?>
Still want a set for the GTA!
later
Jeremy
Old Jan 12, 2005 | 06:25 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Looks awesome so far. When your done u wanna come over and put all that in for me????
Old Jan 12, 2005 | 08:14 AM
3.8TransAM's Avatar
Need to take a few pics of mine while its still airborne in the garage lol...
Almost same setup. Ordering a panhard(adj) and a wonderbar when I order too....
later
Jeremy
Old Jan 12, 2005 | 10:33 AM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
can't wait to hear how it handles after all these mods...
Old Jan 12, 2005 | 04:19 PM
novadk13's Avatar
I can come over if you need a hand when you do it.
Old Feb 13, 2005 | 11:09 PM
novadk13's Avatar
well the stock torque arm is out and I have about half the new stuff on, aside from the vett servo these are the last mods for my car fo a while. I got an engine for my IMPORT truck and most of my time and money will be going towards that, so hopefully by this coming fall my 350 will be getting some work done to it for the winter swap. Also my house is suppose to be done withen the next 3 months so I need to work some more saturdays
Old Feb 14, 2005 | 10:18 AM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
Hey lookin good. Wish i had the money to do all that right now. It will be nice to have another thirdgen in town when you get your house done.
Old Feb 14, 2005 | 03:13 PM
novadk13's Avatar
it will also be nice to have another guy down the block when I do the engine swap
Old Feb 14, 2005 | 07:34 PM
Engine: carbed 383
Yeah thats cool... I'm always willing to help out if I have the time... when you planning on doing that?
Engine: carbed 383
Old Feb 14, 2005 | 07:59 PM
novadk13's Avatar
prob not till next winter or summer, not sure have to see what the funding is at the time
Old Feb 15, 2005 | 09:48 PM
mean57's Avatar
Car: 87 gta
HEY. glad to see the project movin along. if you havn't purchased
a torque wrench yet you can use mine after all you are only 3 mins from my house. if that
also if you need any other tools let me know i most likely have it
retired but still young g.m. technician
decided to hang up the daily bloody nuckles
now i'm a advisor (i deal with pissed off people all day woohoo)
"it costs how much!?!? you !@#$%^&*()" hehe
Old Feb 15, 2005 | 10:25 PM
novadk13's Avatar
I got a new torque wrench when I started the project, nice for a craftsman has a sight dial unlike my dads old snap-on.
The last piece is in WOOOOOOOO got the torue arm in tonight, had to cut some of the stock mount down a bit but turned out alright. All I have to do I adjust the torque arm so I have a -1 degree difference from the trans to the diff. All I plan to do now is get those GTA rims off Mean57
Old Feb 17, 2005 | 03:55 AM
3.8TransAM's Avatar
Man,
When u gonna shove something under that hood that will let u get enough speed to really work that suspension? lol
j/k
looking good, you and I have about the same setup now, least as far as suspension goes.
later
Jeremy
Old Feb 17, 2005 | 04:24 PM
novadk13's Avatar
Man,
j/k
later
Jeremy
hopefully by end of summer have the engine done for a winter swap, not for sure see how much I spend on the house
Old Feb 19, 2005 | 04:16 PM
novadk13's Avatar
Holy crap drove around the hood today (no insurance yet) and this is like night and day, was taking turns at 40 hardly if not any body roll def worth the time and money, this thing is great, just need to get some new rims and better tires now
Old Feb 19, 2005 | 07:35 PM
jay92,85,79's Avatar
Car: 85z28,
Man thats sweet. I hope one day I can have all that stuff under my car. And since u are a pro at doing it feel free to come by and help lol. Hey i just noticed that your jack and stands are the same color as the car. Thats cool
Fast355
Dec 2, 2016 06:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bryan623
Aug 10, 2015 11:33 AM
