Homegrown STB pics
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Homegrown STB pics
Just finished homemade STB and wonder why I didn't do this sooner. I used 1.25x.095" mild steel tubing and 3/16" plate for brackets. Tightened up the front end of the car; I can definitely feel the difference.
Total weight with hardware after paint 7.8lbs
Total cost $60 for steel and $5 for paint
Well worth it!!
Well worth it!!
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Looks good! I'm surprised the tubing even costs that much.
Is it painted in the picture? The STB almost looks bare metal.
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
You'll need to spend another $60 on a grinder to cut it back off the day you need to pull the motor for whatever reason.
Engine: 305TPI
I could be wrong, but I'm sure Lo-tec will tell us.
The lower plate is bolted to the strut tower with two 3/8" bolts per side. Takes about 2 minutes to remove. The nuts are welded onto the lower plate below tubing, and the bolts go in from the underside of the strut tower. STB is not painted in this pic, but is now a nice shade of low gloss black.
Car: Agood2.8,
Engine: V6rsr,
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
I was just talking about building one on a different thread, I like it. You gave some inspiration
Car: 91 RS
If I ever get caught up on other projects I will add these finally...
Car: 91 Red Sled
If you guys put up some plans you should move the thread over to fabrication... you know, for HELPING people instead of bragging .
I really like your brace, great job from an ME stand point. Typical bolt-in STBs have just 1 bolt on each side which does NOT strengthen the chassis fully. What you've done is prevent the strut towers from deflecting with reference to the frame... very good. Infact you've inspired me to make my own. Takes a lot to inspire me (considering I already have a 3 point STB).
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
where have you seen these typical STBs with only one bolted point per side?
Car: 91 Red Sled
Originally posted by 91banditt2
not to high jack this thread but....
His bar puts bending moments on the STB in addition to the tension and compression. This makes it inherintly more useful in stiffening up the front end geometry.
Example of another "strong" STB;
It's already done, you just have to put it together!!
SOME ASSEMBLY REQUIRED (cutting, welding, grinding, painting etc.)
Tube is 49" long. If fabbing one you have to watch the lip under the hood that is a couple inches in from the edge. To set the height I spaced the tube about 3/4" above my fuel rails and worked backwards from there. The lower plates are 2" X 5", and the spacing on the support plates (vertical height from lower plate to centerline of tubing) was 1" on the outside and 2" on inside.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I was going to do this with some square tubing I picked up, but I think it's a tiny bit short, and I believe it's about the same thickness, anyway, I just used it to practice welding on...
That's what I wanted to ask, I figured 1/8" was a good thickness, but that tube you have is only... 13 gauge, compared to 11....
Think that's thick enough to work well? I don't doubt your results, but would 1/8" round work significantly better?
-J
-J
-J
-J
Car: 92' RS
Engine: 357
Axle/Gears: 4.10
I would weigh the bar you plan to use to see how much heavier it would be...this bar with mounting hardware weighed in at 7.8lbs...not really light but not bad.
Great Job!
