1988 2.8 V6multi port problem
Old Dec 6, 2005 | 10:58 AM
Sidnee's Avatar
Hard to start, when it does start it dies when you give it gas, other times (rarely) it will start and run. Have replaced the fuel filter and fuel pump. After I replaced these items, I got a code 44 and replaced the O2 sensor. Checked the Shrader valve on the fuel rail, fuel shot out about a foot. I can hear the fuel pump working and I am getting good spark.
It acts as if something is shutting down the fuel.
Fuel pressure checked at 40+ at start up. Dropped to 38 when first started. Checked the MAP sensor, showed it was bad and replaced it...it still starts and dies, starts and dies. etc. No vacuum leaks, as it does not rev that high. Any suggestions?
I originally posted this on the engine forum and didn't know there was a V6 forum. I could use some help.
Sid
Old Dec 6, 2005 | 11:06 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Check your IAC. Had that problem with mine. Make sure you have plenty of gas too.
Old Dec 6, 2005 | 11:12 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Re: 1988 2.8 V6multi port problem
Interesting... an '88 shouldn't even have a MAP sensor... do you mean your MAF?
Old Dec 7, 2005 | 03:11 PM
TurboGM1's Avatar
Car: 89 RS Camaro
Engine: 2.8 TPI
I'd also check the IAC, but also look into the TPS. Either you're not getting enough air and it's flooding out or you don't have enough fuel getting to the engine. If pressure and spark is good, these are the two to start with.
Old Dec 7, 2005 | 04:40 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
How "good" is your spark?
Any way to tell if the injectors are in fact spraying?
"hard to start when cold"
Battery
"choke" out of adjustment (IAC)
distributor problems (rusted, bent, carbon tracked)
Emissions problems
"start but dies"
bad elec connections are distrib or coil
not enough fuel
vac leak
I would make sure your spark is white.(and check for corosion wires)
Check to make sure injectors are spraying (attempt to flood the engine)
Then check IAC
Old Dec 8, 2005 | 03:54 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
hey also do some reserch on your cold start injector!! sounds like possible cause...............
Old Dec 8, 2005 | 07:16 PM
TechSmurf's Avatar
Engine: LS1, Scrap
'88 had no cold start injector.
Old Dec 8, 2005 | 08:42 PM
Dale's Avatar
Engine: 350 S-TPI
It didnt?
Old Dec 8, 2005 | 09:30 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
mine does
Old Dec 9, 2005 | 11:11 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Really? I thought '88 was when they got rid of em. Guess my brain's confusing them with TPIs. oh well.
Old Dec 9, 2005 | 11:12 AM
Nixon1's Avatar
Will it stay running with some throttle application? Sounds like she's choking a bit. Havent played with the throttle stop have ya?
Old Dec 9, 2005 | 05:38 PM
Sidnee's Avatar
Nixon
No
Sounds like she's choking a bit. Havent played with the throttle stop have ya? No, have not done a thing to the throttle stop. However, I put a new IAC on it and it started running better. I have not had a chance to drive it, since we got 7+ inches of snow last night, when the roads clear up, I will take a test drive.
Thanks for all of the advice,
Sid
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
stalkier
Aug 21, 2015 01:54 AM
Randomtask2
Aug 13, 2015 01:57 AM
mx127
Aug 10, 2015 08:13 AM
