ZZ4 Vs. Performer - Check this pic!
Old Dec 20, 2005 | 09:17 PM
genob4c's Avatar
Car: 86 Iroc
Engine: LG4 305 Powerhouse
Word is the ZZ4 is better. How much better can it be? It look almost identical to my 2101 performer (aside from the ugly egr on the ZZ4, which I don't need. Check this pick of both. They look like twins.
What's the word on the street?
Thanks,
Old Dec 20, 2005 | 09:42 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'm willing to bet, on any given streetable small block, you couldn't tell the difference between the two.
Old Dec 20, 2005 | 10:06 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Ditto,From what I understand,you'd be amazed at how many different intakes come from the same mold.
Old Dec 20, 2005 | 10:22 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Measure the depth of the plenums and compare, then measure the port exits.
If they are in fact identical, the one with the bowtie cast on it will be faster
Old Dec 20, 2005 | 10:25 PM
genob4c's Avatar
Car: 86 Iroc
There is a small hole drilled in each side of the plenum on the ZZ4. You can see the one on the left side in the pic. There is one on the right side also. What's that about.
Old Dec 20, 2005 | 10:36 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Lightweight
That seems a bit weird, if that goes right through you hit oil lol
Old Dec 20, 2005 | 10:42 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Im going to guess the holes have something to do with EGR like the two small holes in the TPI manifold.
Old Dec 20, 2005 | 10:44 PM
Fast355's Avatar
Car: 1983 G20 Chevy
EGR passage on the ZZ4 one. Lets face it sooner or later we will all need that.
Old Dec 20, 2005 | 11:11 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Slight differences. If you had an EGR perfromer it would be real interesting to compare the two.
You wont notcie any difference in power between the two. The ZZ4 is a great peice for upgrading a stock intake but its nothing too special as you can see compared to a cheaper edelbrock intake.
Old Dec 20, 2005 | 11:22 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Yep
The beauty of the ZZ4 intake is the mis-guided people who will buy a ZZ4, yank them off(before coolant even hits them), slap a performer on there, put the ZZ3/4 on Ebay and believe they have accomplished something. Then most people won't even look at them becuase it is a stock GM piece. Makes for a CHEAP find on Ebay or a Swap meet. I paid $20.00 for one at a swap meet!!!!
Old Dec 21, 2005 | 01:40 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I find it quite strange the ZZ4 intake has EGR passages in it, considering the ZZ4 heads are the exact same as the Corvette aluminum L98 heads, which do not have EGR passages.
Old Dec 21, 2005 | 06:57 AM
MattODoom's Avatar
Car: '88 G T/A
They must use the external EGR tube into the manifolds.
Old Dec 21, 2005 | 10:31 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
They did, when required.
How about a pic of both from the bottom (to see the routing), and front (to see the comparitive heights)? And the aforementioned plenum depth measurement.
You can see the cross-over passage of the Performer sticks into the plenum a lot more than the ZZ does.
Old Dec 21, 2005 | 10:43 AM
genob4c's Avatar
Car: 86 Iroc
Sorry. Shipped the ZZ4 back to Summit this morning. After getting the other opinions, I decided they were just too similar for me to justify the cost. Plus I would have had to come up with a blank for the EGR. Easier and cheaper to stay with my performer.
Thanks for the info guys. You helped me make the decision.
Old Dec 21, 2005 | 11:05 AM
five7kid's Avatar
There's no doubt they are similar parts. The ZZ4 manifold carb mount is about 1/2" taller than the stock 305 aluminum manifold, that much I know.
If you don't need EGR, and your thermostat housing doesn't leak ( ), then I agree, it doesn't make much sense for you to change from the Performer to the ZZ4.
Now, had you ordered an RPM manifold...
lt500r55
Sep 1, 2021 01:30 PM
Infested
May 22, 2018 11:56 PM
italiano67
Dec 11, 2016 09:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
