Identifying a WC T-5
Old Jan 17, 2006 | 06:00 PM
Wild Bill Hunt's Avatar
Car: 92 camaro rs
Transmission: 700-R4
I know ther is someone here that can tell me how to identify a WC T-5 tranny. I am purchasing one online and I really need some advice. Yes! Yes! Yes! I have done my research for what time I can get access to a computer but some of us have 3 small kids and half to work all the time ! I have asked before how to identify a V-8 T-5 and had no replies. Any help would truely be appreciated!!!!!!!!!!
Old Jan 17, 2006 | 06:20 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
You need the number of the tag which starts with 13-52-xxx.
The three numbers after 13-52 are what identifies the tranny.
Once you have that number go to http://www.5speeds.com/t5/index.html, scroll to the bottom of the page and select the number from the drop down box. It will tell you what the tranny is.
Old Jan 18, 2006 | 05:27 PM
Car: 92 camaro rs
Thanks , this will really help a lot !
Old Jan 22, 2006 | 07:03 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I did a search for you and found this thread with a picture:
https://www.thirdgen.org/techbb2/sho...hreadid=334831
Old Jan 24, 2006 | 09:35 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Picture is worth a thousand words !
Old Jan 25, 2006 | 09:42 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
nobody ever told me what hth meant lol. but i got a wc and im sure of it so w/e for now, for me at least.
Old Jan 25, 2006 | 10:06 PM
Here's an even better one I found.
It shows both kinds; the old one on top, and the newer on the bottom. Look at the difference in that big bearing in the front of the case.
If your car has its original 86 transmission, it should be the old style. But they're a direct swap, so who knows what might have happened.
Old Jan 25, 2006 | 10:16 PM
ZZ4 86 Z28's Avatar
well my auto broke, and i was buying a t5, and i needed to identify a world class before i bought it.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
Linson
Sep 21, 2015 01:08 PM
DARKmj16
Sep 9, 2015 04:07 PM
