Anyone ever try putting a fan on Ram Air?...
Old Dec 19, 2001 | 09:54 PM
ChevyLuva3's Avatar
I have ram air in my IROC, it sucks the air from two 'plumber' pipes, courtesy of previous owner. The pipes suck their air from behind the fog lights (btw, is that a good place for them? if I were to remove the fog lights would I get more air in? or is there no difference if fog lights are there or not?). Any way though, with ideas of how superchargers work and turbochargers, it got me thinking. How bout if I put a fan in the pipe, so as I go faster and feed more air in, instead of it just being forced in by physics, the fan would shove that air in their, and also give better sucking force. Would this work? Any one ever try it? I was wondering what type of fan, I was thinking maybe a computer fans (ya kno the one ur probably hearing churn away as you read this), that might work. So whatchas think, will it work? Or will there be no difference, with or without the fan?
Old Dec 19, 2001 | 10:23 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
oh my GOD..
TELL me you're joking. I won't even waste my time thinking about why you'd want to do something like that
btw: have you tried rigging up a blowdryer yet?I think that works..
Old Dec 19, 2001 | 10:38 PM
ChevyLuva3's Avatar
Wow, excuse me for having an idea b!tch. Are there any other people out there, with more intelligent thoughts.
Old Dec 19, 2001 | 10:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Don't bother, it won't make any difference. If anything performance will be worse from the restriction of the fan in the air stream.
Old Dec 19, 2001 | 11:07 PM
Joshua Leslie's Avatar
I dont know, i think its a good idea!
A computer fan wouldnt do it though.
U would need something that really pushed a lot of air....maybe a small fan and somehow rig up a belt to go around it so it puses more air as speed increases....like a poor mans supercharger!
Old Dec 19, 2001 | 11:08 PM
rezinn's Avatar
We've all thought of these things. The truth is any power you create with something like that would only cost you power to run it. Im actually tired of telling people why it won't work. Maybe you can design something that makes us all look stupid. Please don't call people names here, even if they are asses. We are only here to help.
Old Dec 19, 2001 | 11:25 PM
ChevyLuva3's Avatar
Yeah, I know a computer fan can't really push much. Using an electrical fan would be great, but I'm thinking of something more practical for the time-being. I was thinking of just putting a fan in there (not electrically operated), I figured a computer fan is small enough to fit. So when the car starts moving, instead of just sucking in air, the fan would start to accelerate, as the car got faster and the fan got faster, the fan would then suck in more air and force more air in also. See what I'm saying. It would almost be like a turbo charger, cuz the fan would take a while to start moving, than Bam, it starts accelerating, sucking and forcing more air in.
But making a electrically controlled fan, is another story, a great one at that, but I would need a lot power to really get it going, and it delves into more of wiring and powering. I was just looking for a simple mod, that according to physics, and turbo and superchargers, should work right? Thanks again.
Old Dec 19, 2001 | 11:42 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Turbo/Super chargers work by feeding more air into the intake than it can use which builds pressure in the intake. For your fan idea to work it would have to move more air than the engine would normally draw at any given RPM. If it couldn't do this then it would not be increasing horsepower, but just acting as a restriction in the intake path. I don't think that you're going to be able to find a fan that can push/pull that much air. Even if it could push that much air you'd have to seal it good so that the pressure could build up rather than just bleed off.
Old Dec 19, 2001 | 11:46 PM
Mark305TBI's Avatar
If, in your last post, you were suggesting just putting a non-powered fan in the intake path it would be nothing but a restriction. The fan would only spin as fast as the air that the engine pulled past it. It wouldn't ever build any pressure since it wouldn't ever actually push any air. All you would have is a neat looking spinning restriction.
Old Dec 20, 2001 | 03:33 PM
Z-Man 85's Avatar
Have you seen the advertisement on TV for a product called a "Tornado". It has fan-like look to it. They have a product for carb and FI. I did't really pay much attention but you put that in the intake tube and it spun or something like that. They dyno'd an Impala SS and they got 20hp. I myself didn't really believe it though.
Old Dec 20, 2001 | 03:42 PM
FormulaKid's Avatar
Car: 1989 Firebird Formula
The tornado doesn't spin...it just has fins which are supposed to move the air in a tornado like motion. If anything all it does is clog up the intake.
As far as a fan goes, it is not bad to come up with new ideas. However, most superchargers spin at about 20,000+ rpm. Most electric fans won't even come close to that. There is a product out called the e-ram which is an electric supercharger. The only problem with that is it only puts out about 1 psi of boost which is nothing. And for $299 it isn't worth it and it doesn't work on anything bigger than a 5.0l engine.
Old Dec 20, 2001 | 03:57 PM
z28dan's Avatar
I don't think a fan (computer fan) would help, it would most likely hinder. Just think of the CFMs moving through your setup when your doing 45 MPH. I did a lot of testing with my ram air this summer. I don't have EGR or the coolant running throught the TB, I have to 2 big 90 degree elbows where the fog logs were. I noticed a +20ish degree drop in temp in the plenum (120 without ram air/ 90ish with. Well that's what the computer read. I don't like it that it's a "bottom feader" system, I needed to clean my filters twice this summer. I also added a bit of fuel in the prom with the ram air installed. To be honest I realy didn't see much HP improvement.
Old Dec 20, 2001 | 05:32 PM
ONEFORMULAOVERALL's Avatar
c-luv
i have thought of this idea my self and all u have 2 do is get creative.
what i have done is use a 4 inch pvc pipe with a splitter that looks like an r ok now u take a leaf blower (craftsmam i.e) and take out the motor mine was 4in. in d. install it 2 the hook side on the r pipe seal and add a k&n. on the straight side just add the filter.
now u have no in line restrictions just mabey doubling your air flow
if u would like me 2 b more in general let me know.
and this is on a firebird also but will work on cam also just get 2 r's and 2 blower motors
Old Dec 20, 2001 | 07:42 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
If you want hook up a "ghetto" intake use a leaf blower. I tried this in one of my other cars just using an extension cord to test it. Squealed my tires all the way up the driveway it was pretty funny. Never fully hooked it up, just did it as a joke and was surprised at how much more power I got.
Old Dec 20, 2001 | 08:42 PM
how did you drive around with a leaf blower? what was the power source?
Old Dec 20, 2001 | 09:26 PM
its amazing how many short minded people r on this board!
u dont know me nor my eye 4 uniformity,so please dont knock if u dont want 2 come in
(LEAF BLOWER MOTOR) take off everything but the motor & elec. wires.
the power source is runned by the batt. of course but with a relay switch. on off anytime.
Old Dec 20, 2001 | 10:22 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I never drove around with it I just wanted to see if how power it would add. Then I took it off. I was running it with an extension cord and I only tried it in my driveway (I have a long driveway). I am not suggesting you do this to your car. I did it just for fun when I was bored in the summer.
I did have a big power boost; I did it on a 98 Malibu V6. Makes me want to buy a supercharger for my camaro.
Old Dec 20, 2001 | 10:42 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
What kind of leaf blower did u use? I want to try this **** hah, instead of my home made 2 inch ****. did u jsut hook up the power wires to the battery?
Old Dec 20, 2001 | 11:50 PM
Momar's Avatar
For one thing, this is freaking retarded. Even if you did get boost it would only last in the lower rpms, and that v6 doesnt need as much air as a 350. I think that it was a kind of interesting but funny test, but anyone who considers seriosly doing this I have to wonder about. When you get into the higher rpms the motor is going to need more air than it did just taking of from idle in the driveway. When you need the more air, the (leaf blower) motor is not going to be able to keep ahead of the air needed by the engine much less give it extra boost. It will then just be a restriction.
Ben
Old Dec 20, 2001 | 11:59 PM
Oneformula overall, I dont understand how you would run a leaf blower of an automotive battery.
for 1 thing, it is DC. for another, its only 12 volts, a leaf blower takes 120. and proly several hundred watts.
Does anyone know how many Watts a car puts out? I have never heard this discused anywhere.
Old Dec 21, 2001 | 12:24 AM
Enkil's Avatar
Well... if the batteries in our cars are 12 volts rated at about 800 amps, that means the battery can put out around 9600 watts. This isn't sustained very long, of course.
Old Dec 21, 2001 | 06:13 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I said I used an extension cord, because I tested it in my driveway, never on the road. A leaf blower runs off AC so in order to run it off your car battery you need an inverter.
If you ever want to try it for fun or if your bored just try it on a smaller engine car like a V6, like I did. You will get it much better results, very very funny too!!
Old Dec 21, 2001 | 06:36 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
What!?!?
Old Dec 21, 2001 | 04:22 PM
drumike102's Avatar
ok this is definatley possible and in fact they sell it. Just a few minutes ago i was watching tv and they sell this thing called the tornado that spins the air and increases hp. It added like 10hp to a 2000 impala. its like $75 though so not really worth it. but it definatly does work.
Old Dec 21, 2001 | 04:24 PM
FormulaKid's Avatar
Is there an echo in here?
Old Dec 21, 2001 | 04:36 PM
SoCo80p's Avatar
it will do nothing, a fan moves on average about the same speed of 30 MPH air, so if your going over 30 MPH you'll be putting a drag on the air, plus one of my buddies got real into the ram air stuff to see what it can do. he has a 69' firebird that runs mid 11's he took one of those ram air box ram air kits, put the tubes into the headlights and right into the carb, a straight shot, and from all his efforts he came to the conclusion that every 10 MPH over 40 will make a average 1-2 HP and this is on a very deep breathing 455 so figure probley less on smaller engines. after he saw the poor results ram air actually gives he took it all off,....but cowl induction on the other hand is about twice as effective (notice how nascar uses cowl induction and not ram air?)
Old Dec 21, 2001 | 05:24 PM
Engine: 305TPI
all i can do is laugh, lol.. we used to joke about this kinda stuff amongst the guys when I worked at AutoZone, never thought someone would actually try to do it
Old Dec 22, 2001 | 11:44 PM
85 Berl's Avatar
Get a gas powered leaf blower, and put it on a 4 cylinder. That may actually build a little boost. Maybe the same as the E ram? I bet it would sound crazy, though.
Old Dec 23, 2001 | 02:08 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
I think ya'll be better off with a vacuum cleaner your the tailpipes
Ken
Old Dec 23, 2001 | 02:12 AM
Momar's Avatar
Ken
Actually if you do both you could double the effect. Who needs nitrous anyway when we have home appliances. I like to travel with a washer dryer in my back seat incase I spill anything on my shirt in mcdonalds drive through.
Old Dec 23, 2001 | 02:27 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
My sides hurt lol
My eyes are watering too ... ahhh,,, the good old days of the infamous Deckercharger
LoL
It never fails to be funny...
Old Dec 24, 2001 | 03:15 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by Momar
For one thing, this is freaking retarded. Even if you did get boost it would only last in the lower rpms,........
Ben
What do you think turbos do? Go drive any stock turbo engine and after about 4000 RPM, watch the boost guage drop.
That's caused from the waste gate, but it still has the same effect as what you're saying.
You're then saying that a turbo decreases the airflow into the engine at higher RPM? No. It just stops boosting. It has lost the resistance it needs to build pressure, and therefore no more boost. But it doesn't hinder flow after that.
Now an electrical powered booster might do that, but that's a big "MIGHT". If the incoming air is moving faster than the electricity can spin the impellers, then the electricity isn't gonna hold it back.
Of course you'd need a diode to keep the blower from then producing more elec than it's getting. But the elec. motor would never put a load on the airflow.
It can (and has) been done. (Not with a leaf blower though.) I think Eaton makes one. But it uses a lot of electricity. Enough to build up the load in the alt. to add more resistance and rotating mass to the engine. But then again, so does a roots type or centrifical supercharger.
They all have there downfalls, it's just a matter of personal choice and use.
AJ
Old Dec 24, 2001 | 07:34 AM
Momar's Avatar
Yes but with a turbo even though it stops making boost that is not because it is spinning to slow to flow the ammount of air needed. It is still spinning faster at higher rpms and therefore flowing enough air to not be a restriction. And I have driven a turbo car sort of. I dont know what is typical of most turbo cars, but on my old f*rd turbocoupe it would run 10 # of boost untill it hit about 4400 rpm and then would jump to 15 #. I dont see why a turbo cars boost would drop at higher rpms. It should stay steady because the wastgate should let everything out after a certain amount of pressure(not airflow) if I understand correctly.
Ben
Edit: I know that it is not directly the rpm that caused the boost to go up, it was the computer controling the wastegate but the turbo was still spinning fast enough to not cause an obstruction in the intake. The boost was still available when the wastgate was adjusted.
Old Dec 24, 2001 | 12:06 PM
PMD Power's Avatar
Why not just use a gas powered one?
tap into the gas tank and run it to the blower and make a feed for 2 cycle additive to it and you are set... get atleast a 1 HP one.. other wise it will not do much help..
I saw atleast a 75 hp gain from doing it to my 455
EDIT: I almost forgot... for more of a punch adda 50 shot to the leaf blower.. you will not be dissapointed!
Old Dec 25, 2001 | 01:04 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hahaha you gotta check this out
goes alont great with this subject!!
http://www.bimmers.com/m3/hoax/index.html
eightsixseven
Dec 16, 2024 01:50 PM
bryan623
Aug 10, 2015 11:33 AM
Leggman1
Aug 6, 2015 04:15 AM
