Problems part II: Dyno complete...
Old Dec 23, 2001 | 07:57 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Link to original topic for tose that care: https://www.thirdgen.org/techbb2/sho...threadid=48182
Anyhow, I did the dyno run yesterday on the local Mustang dyno. Very disapponted would describe my results. In my quest to finally break 300rwhp, I managed to drop 4rwhp and lose 53ft-lb of torque. And I had a huge oil leak that seems to pop up when I rev past 4 grand. An oil leak that cut my runs short. The leak is somewhere in the back, either the block to intake seal, or the distributor spacer. The only brite side was that the peak hp raised 600RPM to 5.6k and torque raised 800RPM to 4.8k. And I got my speedo calibrated
I think there was a fault in the run, and a second run could have been better. The run showed a little knock between 4900 and 5300, so that probably hurt. I'm also not sure the operator was totally on the throttle. While watching the run on the computer, the cursor for the fuel map took an odd path to WOT. That leads me to believe something was amiss.
I suppose a better run with new ignition components and fresh oil might yeild a better run, but at the moment I'm torn as to whether I should keep the LT1, or go back to the TPI. Opinions?
Oops, I guess I should post the numbers:
power: 268.2 @ 5600RPM
torque: 254.2 @ 4800RPM
Old Dec 23, 2001 | 02:14 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Keep the LT1 intake. My guess is once you find out the problems you will love it. I'm in the middle of swapping out both of my cars to the LT1 intake so I don't wanna hear of anybody givin up. Let me know what you find.
Old Dec 23, 2001 | 02:23 PM
Guest
Guest
Posts: n/a
Were both runs on the same dyno?
Old Dec 23, 2001 | 03:08 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: 9", 4.33:1
No no no..... I am another one of the guys that is about to do this swap and I don't want to hear about ANY problems........
I am not sure what the problem could be, but it sounds to me like that run isn't indicative of the potential of the engine. Don't give up hope!!
Good Luck!!
Laterzzzzzzz
Old Dec 23, 2001 | 05:44 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Sorry to hear about that. I expected to see the loss in TQ, I can feel it with just plain old SOTP's.
Also, dynos differ alot so unless the orginal run was on the same dyno as this one it doen't mean alot.
Old Dec 24, 2001 | 10:31 AM
RCR's Avatar
RCR
Yes guys, it was on the same dyno. My last three outtings were on this dyno. It does feel better than the TPI. The only thing that was really different from last time was that I locked the convertor. We'll just have to wait and see...and get that leak fixed.
Old Dec 24, 2001 | 04:32 PM
David 91RS/Z28's Avatar
RCR.....what are your other mods?
Old Dec 26, 2001 | 12:32 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
have you modifyed your prom for the LT1 intake? Maybe thats why you are not getting very good results?
Old Dec 26, 2001 | 09:24 AM
RCR's Avatar
RCR
89 IROC & David: Mods are on my site, gets too long to list As for the program, I have a DFI setup. It may not be program perfect, but it is pretty close. The run showed some knock, so adding fuel in that area might help (or might not). But not to the addition of 50hp. Something else needs work.
Happy Holidays everybody...
Old Dec 26, 2001 | 06:45 PM
RCR's Avatar
RCR
I got a scanner for Xmas, so here are the dyno runs: (sorry, they're obviously upside down)
Old Dec 26, 2001 | 07:22 PM
Engine: 4.0L
I couldn't stand them upside down.
Old Dec 26, 2001 | 09:46 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Thought about a different cam that would have a higher duration?
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Reborn756
Sep 4, 2015 03:42 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
