[RI] FACTORY Vacuum TCC Lock up
Old Jul 18, 2010 | 09:57 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Need to locate a FACTORY TCC ( Torque Converter Control ) harness and solenoid from a NON-ECM ThirdGen. This will most likely be found on Export cars.
Here's a picture of exactly what I need. ( Note - There is only 1 Soleniod; this pic shows 2 only because the car this harness was pulled from was an Canadian 84 TA with functional hood flaps. )
Please send pics/prices shipped to US Zip code 02827.
Thanx in advance !
Old Jul 19, 2010 | 09:21 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: FACTORY Vacuum TCC Lock up
That's not the whole setup is it? I'm assuming the square gray pass-through is what goes in the hole where the ecm harness would normally reside. That pigtail must plug into something, I'm guessing another harness that goes to the fuse box?
Old Jul 20, 2010 | 10:57 AM
John in RI's Avatar
Yup,.....
Tha's it - The set-up pictured is from an 84 Trans AM.
Once the harness is connected thru the pass side foot-well it's connected to the dash harness C207 connector. I believe that one of those wires was for the ALDL and the other was for the brake switch. Third wire was Black for ground IIRC.
The harness runs into the engine bay where the ECM harness would be, Then behind the engine where it splits and drops to the tranny plug - & over to the drivers side to the Soleniod bracket ( bracket was mounted on the drivers side of firewall)
Old Jul 20, 2010 | 01:03 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Give me a day or 2 as I think I have what you need. It came from a 84 camaro if I have it, if that makes a difference
Old Jul 20, 2010 | 07:59 PM
John in RI's Avatar
Waiting a few days is NO PROBLEM !!
The last one I had was from an 84 and I used it on an 88 Dash harness that was connected to an 85 Engine harness. It should not matter what year it's from....... I think I can get it to work.
Thanx in advance !
Old Jul 26, 2010 | 01:39 PM
6SIX6's Avatar
Car: 89 IROC
No such luck here at the house as I went through every box I have here. It might be at my shop in a box. I will check when I go up to it on wednesday night
Old Jul 27, 2010 | 11:22 AM
John in RI's Avatar
Thanx you VERY much for taking the time to look for me...... I've run into trouble finding one as well as trying to get the one I already paid another member for.
Here is another picture for anyone else that might have one. It shows where the Solenoid is bolted down to the firewall bracket on a Trans Am. It uses an independant harness so removing it from a car is really very easy to do.
Thanx Guys !
Old Jul 27, 2010 | 12:31 PM
6SIX6's Avatar
Car: 89 IROC
Does what you need come with the relays on eiher side of it in the picture above??
Old Jul 27, 2010 | 01:59 PM
John in RI's Avatar
Nope,....
Don't need any other relays or the mounting bracket, Those relays are part of other systems and not needed for the TCC set-up.
The pic I posted today was basically a reference just so others can see where the factory placed the TCC solenoid.
Old Jul 27, 2010 | 02:18 PM
6SIX6's Avatar
Car: 89 IROC
Nope,....
Cool as i was looking for the harness in the top pic and just wanted to know if I needed something else to add to it. i know I removd it from my 85 camaro and I know I have that part but I got to find the wiring still for it. If its in my car still Ill just take it out as i dont need it anymore as I went T56
Old Aug 8, 2010 | 11:00 AM
John in RI's Avatar
Bump !
Old Aug 9, 2010 | 12:05 PM
6SIX6's Avatar
Car: 89 IROC
Still looking for yah as I havnt forgotten but I havent had much time to go thru my shop as its a disaster right now. In this pic to the upper left is thatthe piece you are looking for??? Its an old pic and Im having troble finding the box I put it in as thats the piece off th firewall I took out
Old Aug 9, 2010 | 06:04 PM
John in RI's Avatar
Yup,
That looks like the correct vacuum solenoid alright !
Old Aug 15, 2010 | 08:31 AM
6SIX6's Avatar
Car: 89 IROC
I FOUND IT!!!!! Let me know if you still need it and ill get it to you ASAP
Old Aug 15, 2010 | 10:18 AM
John in RI's Avatar
PM Sent !
Old Apr 6, 2011 | 09:30 AM
John in RI's Avatar
Bump,.........
I Need another one !
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
SlowAZ28
Sep 2, 2015 05:19 AM
