Need VSS buffer box
Old Sep 14, 2010 | 03:15 PM
Hyper Tailz's Avatar
Car: 92 Camaro RS
Engine: 3.1
Transmission: Manual
Need VSS buffer box
Like the title says. i need new/used vss buffer box.. i perfer new. its for a 92 camaro v6 3.1. any info to where to get one or anyone selling a working one would be great.. just to clarify the vss box is what controls the speeometer and odometer motor through 4 wire that clip on...
Old Sep 14, 2010 | 04:26 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Need VSS buffer box
yellow colored one behind cluster?
i may have one still if i can find.
id have to dig around and see if i can locate again.
got any gm numbers on the one you need, to match up?
email or text me if you dont see me again real soon
good luck
Old Sep 14, 2010 | 04:43 PM
Car: 92 Camaro RS
Engine: 3.1
ill check when i get home i am at work if anything ill text u. ill try to get a pic up soon of what i need. the location of it is right under the speedometer. i know it controles the the speedodometer cuz i have it off right now and i dont know whats my MPH but it also connects the odometer motor to turn the gears to know how many many i have done
Old Sep 14, 2010 | 05:43 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I've got a spare cluster from a 92 V6. I looked at it a little while ago, do you mean the little printed circuit board under the speedo that has a ribbon type gray wiring thing that comes from the speedo plugged into it? Or would you rather have the whole speedo with it too?
Old Sep 14, 2010 | 05:55 PM
Car: 92 Camaro RS
Engine: 3.1
yea that what i am talking about. i just need the lil board if it works
Old Sep 21, 2010 | 02:33 PM
Car: 92 Camaro RS
Engine: 3.1
Bump anyone got a vss buffer
Old Sep 22, 2010 | 09:08 PM
Car: 92 Camaro RS
Engine: 3.1
BUMP BUMPPP for the vss buffer
Old Sep 23, 2010 | 01:32 PM
Car: 92 Camaro RS
Engine: 3.1
BuMmMmMmMmP
Old Sep 23, 2010 | 05:21 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I've got the one from the cluster I have. Took it out and the solder joints all look like new; of course that doesn't mean it works because it looks good. I have no way to test it, but I'll send it priority shipped for $15 if you want to take a chance on it. I won't guarantee it or anything, but it's an option. Up to you?
Old Sep 24, 2010 | 10:25 AM
Car: 92 Camaro RS
Engine: 3.1
i am willing to take the chance but in the case it doesnt work will you procces a refund???
Old Sep 24, 2010 | 11:17 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Read this again. It says basically that I don't know whether or not it works, it only appears undamaged to the naked eye. I am willing to sacrifice the cluster and sent this to you if you think the risk is worth the possible benefit. I am charging you for the shipping costs, gas, and effort on my part, and stated I wouldn't guarantee it. So that pretty much means no refund. This is not meant to be a shady deal, I just thought I would offer you an alternative considering your apparent urgency to find something. It's up to you
Old Oct 4, 2010 | 05:54 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
umm... the 92 camaro with the 3.1 doesnt have a "buffer" box, all of that is controlled through the ecm itself directly to the cluster
Old Oct 4, 2010 | 06:16 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Well I figured out what he was talking about and described it further up on the thread and sent him what he wanted. He told me it worked so we managed to solve the problem regardless of the improper terminology.
Old Oct 4, 2010 | 06:22 PM
Pillsbry10's Avatar
good deal
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
tattmann
Sep 27, 2015 05:20 PM
