Speed density auto engine wiring harness
Car: 86 Iroc z / 91 RS
Engine: LB9 / looking for a bbc 396
Axle/Gears: 2.73 both for now
for a camaro i have a 91 rs i wanna put a 87 iroc tpi 305 in but i need the 90-92 harness and i dont think i have to change the ecm
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Speed density auto engine wiring harness
https://www.thirdgen.org/forums/engi...to-engine.html
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
If your RS is tbi the ecm would be a 1227746' you can use this ecm if you send it to dynamic efi and purchase there ebl and port fuel mod, the tpi maf used a 1227165 ecm 86-89 and the speed density tpi in the f body used the 1227730 ecm . There is a harness being sold in the classified section.
He also wants a Camaro harness. Battery location is different on the Camaro and the Firebird. You might want to get a 86-88 harness, 89 is a little different due to the deletion of the 9th (cold start) injector. I would get a 90-92 TPI intake and a 91-92 TPI ewh. I believe the 90 ewh was slightly different.
well i have a whole donor car its a 87 irocz but im told that the harness is too different for the 91 ecm
Car: 91 Formula
88 harness is setup for a serpentine belt setup. 87 and older have the bracket v-belts setup. IIRC the Alt. and A/C comp. are on the opposite side. You could modify those wires to work. I believe 85-87 Camaros had cable driven speedos.
ok i can get a 91 z28 ecm for $80 from advance and that should do the job right?.. now i just need the harness for a good price anyone can help me out
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Ive got a complete sd harness 150 +shipping
