January 2015 COTM **WINNER**
Old 12-31-2014, 10:23 PM
COTM Editor (Retired)
Linson's Avatar
Car: 89 Formula 350, TTA
Congratulations to John in RI for being voted in by the TGO Community as January 2015's Car of the Month with his kick-***, LT1-powered '84 Berlinetta.
This car seemed to me like a dark horse going into the competition (what with awesome looks of CharcoalBird's Firebird, plus the stunning quality and seemingly large fan base of 86'sportcoupe's Camaro). it may have been an appreciation for the performance and technical achievement that went into this car that got the win. and it looks pretty killer too.
'Mean Green' was stripped of every nut/bolt and the entire body was stripped to metal (firewall, door sills - everything ) and re-painted a couple years ago. From the factory it was a mild mannered LG4/auto with 3.08's, but it's been converted and modified several times since I bought it back in 92'. Most recent stats:
LT1, LT4 springs, LT4 Knock Sensor, Full Steel RR's, Composite Valve Covers
T56, Stage 3 clutch, Aluminum Shaft, 98' ZT POSI with 4.11's
LS1 Slotted/Drilled Brakes Front/Rear
Jegster SFC, 36mm front, 25mm Rear Bars,
Poly Bushings Front, Rear, Motor Mounts, & Tranny Mount
ZR1 Wheels, 275/40/17's
Dyno Don 1 3/4" Headers, Random Tech 3" Cat, Magnaflow 3" Cat-back
Duel Lier Siegler Conteur Buckets, custom "CAMARO" upholstery
8 Speaker BOSE, 12 Disk CD Changer
4th Gen Keyless Entry, Twilight Sentinal Rear View, AC Delete
Intelletronics Speedo (top speed 1/4 mile, ect... ), 5500 Red-line Tach
Daytona Cowl hood, 87+ Rear Fin / 3rd Brake Light, 'Wet-Arm' Wipers
New Weather-Stripping
ALL power options; Even kept the factory Rear Wiper
Old 01-01-2015, 09:17 AM
Brother Al's Avatar
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
Re: January 2015 COTM **WINNER**
Congrats John!!!! Great Way to start the new year!
Well deserved my friend.
Old 01-01-2015, 09:32 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Very very nice John, Congrats on the win !!!
Here's to your signature
Old 01-01-2015, 09:40 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Congrats John! Car looks awesome!
Old 01-01-2015, 10:09 AM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
Have to vote for a fellow lt1. What's the 1/4 mile time?
Old 01-01-2015, 12:34 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
THANX TO ALL !
First to Linson for his time and effort keeping up with the COTM here @ TGO. It's a GREAT way to highlight some of the most awesome Thirdgens on the streets today.
I'd also like to congratulate the other members that have been nominated this month - and in past months. There might only be 1 COTM,... but there are surly no "losers". If your ThirdGen got nominated it's because other members appreciate and respect the way you've crafted your ride - TAKE PRIDE !!
I bought Mean Green for $2500 back in 92'. Drove it everyday thru college while delivering pizza in it at night. I've taken it off-road, crashed it into a snow-bank, again into a guard-rail, loaded furniture onto the roof while moving (yes, it's got T-Tops) and spun it 360 degrees off a highway ramp once. ( little too fast into that corner !! ) It's got - almost -as many scars as I do, and I wouldn't want it any other way !!
jaybdaboat - no 1/4 mile times since the LT1 got installed. I had a pretty significant vibration @ 90+MPH when it was first put back on the street. I was going to swap the aluminum shaft and then found the problem,... turned out to be a bad rear flange. Now that It's fixed & I can get past 100 with the car is stable, the 1/4 mile test will happen next spring !!
Again - I'm greatly honored,........ THANX to ALL !!!!
Old 01-01-2015, 01:19 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Congrats man!!!! Cool that you have so much history with it since 1992!!! Beautiful thirdgen and great job overall on it!!!
Old 01-01-2015, 08:03 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
She's a beauty. Congratulations!
Old 01-02-2015, 11:11 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Congrats John! Mean green is looking great as always!
Old 01-02-2015, 11:57 AM
GPSkinzhut's Avatar
Car: 87 IROC Z, 2010 2LT
Engine: 305 TPI, 3.6 V6
Transmission: 5-Spd, 6-Spd
Axle/Gears: G92 3.45
Grats John! Well deserved, bud!
Old 01-02-2015, 02:06 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Congrats man! Car looks great!
Old 01-02-2015, 06:17 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Congrats, John! You have put a lot of time, money, and especially detail into the car. It looks great and the win is well deserved.
-Jim
Old 01-02-2015, 06:35 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Nice! Congrats
Old 01-02-2015, 07:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Congratulations,
Old 01-03-2015, 07:36 AM
TkernIROC1986's Avatar
Car: 1986 IROC-Z
Engine: 5.7L TPI L98 350
Transmission: 700R4 Auto
Axle/Gears: 10-Bolt Posi Disc 3.73s
Congrats on the win! That is one mean looking Berlinetta!
Old 01-03-2015, 08:18 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
Congratulations on the win!
Old 01-04-2015, 02:50 PM
John in RI's Avatar
I REALLY can't say thank you enough guys ! It sure has been a long haul and my ride would NOT be what it is today without the help from MANY of the members here over the years.
Not only does being recognized as TGO COTM bring me a certain level of self-pride, but it also allows me to 'keep even' when it comes to braggin' rights with my little bro,... his car was voted COTM on the IMPALA forum a few months back !
Chevy pride runs pretty deep around here !
Old 01-04-2015, 02:58 PM
86'sportcoupe's Avatar
Car: '86 Sport Coupe
Engine: 310"
Axle/Gears: Stock 10 bolt. 2.73's
Congrats!
Old 01-08-2015, 12:32 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Nice car... but how does a car reach this level of detailed restoration without having blisters or louvers bolted onto it? It looks unfinished?
Old 01-08-2015, 11:21 AM
John in RI's Avatar
The pic that was posted when it got nominated shows the louvers installed.
The top pic above is one that I posted in the voting thread, it was taken just before the Louvers , Magniflow Cat back and CSR electric water pump got installed. There's another pic I posted showing the front suspension - and there's no motor installed in that pic but obviously,... the motor is installed now. Still really can't call it 'finished', I've still got to paint all the 'nose holes' black and re-install the rear wiper Hatch Louvers too.
I just didn't have many pics from last season & realized that the ones I did have from meets/gatherings usually had the hood open,... so I used the pics I had available.
Old 01-08-2015, 08:06 PM
twood's Avatar
Car: 87 LT Convertible
Engine: 357 4bbl
Congrats John! You deserve it. Now I feel like I got to rub elbows with a celebrity.
Old 03-05-2015, 11:47 AM
Topspeed's Avatar
Car: '84 Firebird
Transmission: 700r4 with kit
Axle/Gears: BW 3.73 Posi
Just noticed this... Congrats John
Old 03-06-2015, 10:21 AM
John in RI's Avatar
Thank You !!!
Still looking forward to getting close to that Pontiac of yours for a closer look. Easily one of the finest restorations I've seen in years. With any luck we will meet up at one of the New England meet-&-greets this season !
Old 03-07-2015, 03:22 PM
Topspeed's Avatar
Car: '84 Firebird
I will try and make it out to one this summer. Can't wait for all of this snow to melt
Thank You !!!
Linson
09-25-2021 07:55 PM
Silver Spear
South East Region
18
12-04-2015 09:59 PM
plm99
Southern California Area
11-16-2015 05:21 PM
Linson
10-01-2015 09:50 PM
Linson
09-21-2015 01:08 PM
Quick Reply: January 2015 COTM **WINNER**
