Do I need a Scatter Shield
Received 1,672 Likes
Re: Do I need a Scatter Shield
Yes.
Sliced up a bell housing like it was butter and cut a nice slot in the pass side floorboard.
Luckiest day of my life, I'd say. Used up all the luck I ever had in that one instant. I have no more.
I'd be more concerned with exploding transmissions with a T-5 though. It should largely protect the clutch.
All the same, a blanket is a good idea. Make sure you get something that wraps the transmission as well as the BH.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
I like my feet so I felt the money for a Lakewood bellhousing was worth it.
Yes.
Sheeeeeeeeeeeeet. What happened? Hard launch? Any signs?
Yup; 6500 RPM, stout transmission, 12-bolt rear, heavy car. Let go the next day. Vibrated some in between but ... surprised me anyway. Also twisted the shaft part of the clutch gear out of the gear part. (didn't know until then that it was a 2-pc part)
That's crazy sofa. Glad it worked out ok.
The way I see it is that I only ever really 'thrash it' when I'm safely in gear. I don't run drag radials or slicks and never will. I probably won't even 1/4 mile it. I wonder if the kevlar blankets are a good compromise?
Engine: 4++,350 & 305 CIs
Even happens with autos
plasmeh
05-04-2018 11:43 AM
89blues
09-29-2011 01:32 AM
lunatic_magnet
10-17-2003 10:00 AM
