internal combustion engine info
Old 08-24-2004, 03:35 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
what up yall? I just wanted to know if someone can give me a better understanding of how the engine works. what im confused on are things like cams, pistons, gas, coolant, water and air. ive been reading articles on TBI, TPI & CARBS. Things ive been reading seem to talk a lot about cams and cranks and suspension and stuff like that. But the majority talks about fuel systems and engine cooling. Im confused on the routs of these things take. I have a good understanding of the engine, but im confused on the routing in the engine that they take. for example, why is fuel consumpsion so more important than anything els? basicaly why is TBI or TPI better in performance than a CARB. where doese it burn and why does it cause the car to go faster? what rout is the coolant taking? what are the pistons doing? Is oil just a lubercant? whats in a v8 thats not in a v6 besides more cylinders? just want more understanding from the best which are you guys.
If this is to much to answer can someone please direct me to a site that gives the basic function of the internal combustion engine. THANKS TO ALL THAT ANSWER.
Old 08-24-2004, 03:41 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Re: internal combustion engine info
[QUOTE]Originally posted by mory
[B]what up yall? I just wanted to know if someone can give me a better understanding of how the engine works. what im confused on are things like cams, pistons, gas, coolant, water and air. ive been reading articles on TBI, TPI & CARBS. Things ive been reading seem to talk a lot about cams and cranks and suspension and stuff like that. But the majority talks about fuel systems and engine cooling. Im confused on the routs of these things take. I have a good understanding of the engine, but im confused on the routing in the engine that they take. for example, why is fuel consumpsion so more important than anything els?
Because if the engine gets too lean, it will burn up the pistons. If it gets too rich, it can burn up the rings and blow through the seals and cause massive leaks due to too much crank case pressure.
Carb, has limitations. In alot of situations is is just not as reliable as EFI.
The air fuel? in the cumbustion chamber, in the bore of the piston hole, above the piston as it rises on compression.
Typically the coolant goes from block to pump, to radiator to block.
They rise and fall with the crankshaft. This causes pressure and vacuum depending on the motion.
And it also acts like a coolant to metal surfaces, it takes the fricton created, and turns it too heat.
Basically, nothing more. Same basic operation. Just more parts
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
here try this it should help to answer some of your questions for you http://www.howstuffworks.com/engine.htm
Old 08-24-2004, 04:17 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Beat me to it. Read this.
Old 08-24-2004, 04:21 PM
THEGENERAL's Avatar
i was just a little quicker this time ...probably wont happen again thou...LMAO
Old 08-24-2004, 04:26 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
How does an engine work?
Suck, Squish, Bang, Blow.
Old 08-24-2004, 05:08 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
You guys are great thanks. valve stuff seems a little confuseing to me. is there an explosion going on with the spark plugs and the pistions at any time?
Old 08-24-2004, 05:11 PM
THEGENERAL's Avatar
when the spark plugs ignite the fuel there is an explosion of the fuel burning and that helps shove the piston down into the cylinder hence the power stroke of the 4 stroke engine
Old 08-25-2004, 11:27 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Oh that's great, its going in my sig.
Old 08-25-2004, 03:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL! I had heard that, except as "Squeeze" and not "Squish". I mentioned the 4 cycles of an engine to a chick once, and she was like "Oh! I know those! It's suck... squeeze... bang... and blow!" I didn't expect that outta her.
Old 08-25-2004, 03:55 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
No Futher Comment
junkcltr
08-02-2019 11:12 PM
TheExaminer
08-25-2015 07:34 PM
InfinityShade
08-22-2015 08:00 PM
bradleydeanuhl
08-12-2015 11:48 AM
BBSDesigns
08-11-2015 07:39 PM
Quick Reply: internal combustion engine info
