4 barrell throttle bodies?
http://www.gtoracing.com/automotive/...d/throttle.asp
i can't find that on holley's website anywhere. does anyone know anything about it/have experience with it?
Car: check
Engine: check
Transmission: check
Re: 4 barrell throttle bodies?
http://www.holley.com/HiOctn/ProdLin...IA/FMSFIA.html
This is a link directly to the 900 CFM 4BBL TBI:
http://www.holley.com/HiOctn/ProdLin...A/500-16S.html
Price's are competitive to a new carb too.
RBob.
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
You need two additional injector drivers.
Read this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=154902
Read this thread:
Car: check
Engine: check
Transmission: check
Read this thread:
Read this thread:
There are two ways to do this. One is to add the two drivers internal to the ECM. The second method is to add an external driver box. Both are accepted practices. Just pick the one that suits your talents/requirements/needs and go with it.
This will work.
There are the National Semiconductor (www.national.com) LM1949 and then the OnSemi, used to be Cherry, CS-453 5-pin To-220 cased device.
I'd really like to see someone do this. On the DIY-PROM board a guy YELLOWBB(?) has done this. He isn't finished tuning yet, but it is working out for him. He is using a '747 w/an external driver box.
RBob.
Car: 91 Red Sled
The only reason I'm reluctant to go witht he 4 barrel TBI is the injectors. I was under the impression that they used the crappy injectors still. I've been getting better with solid works and the plan is to make my own injector pod that housed GM injectors.
Tough project.
Tough project.
Car: check
Engine: check
Transmission: check
Tough project.
Tough project.
The pictures do show the black plastic caps. I think that means that they are the old style. Oh well.
RBob.
Car: check
Engine: check
Transmission: check
Just got it on good word. The Holley 4BBL TBI's also use the Delphi injectors. These are the 'good' ones. Holley has been using these for 2-3 years now.
I would use one of these TBI's.
RBob.
RBob.
Originally posted by RBob
Don't know. I had thought they were the newer Delphi injectors. If they are the older ones then I wouldn't use it either.
RBob.
RBob.
I dug up this old post while searching on holley 900 4bbl stuff ;-)
Ben.
Engine: LO3;383tpi
Yes, the black caps indicate the old mopar style injector. Those injectors have a bad rep, seems mostly due to a short life span and poor spray patterns from what I have read.
The only experiance I have ever had with them were on my father's '89 ram, which came stock with a holley tbi (though the injector pod sits down much farther than the 670). Anyways, at 2XX,XXX miles, one finally went bad. But I'm not sure if they are exactly the same as the ones on the 4bbl tbi.
The Delphi's are possibly able to handle a 100psi, I'm not too sure about that, but someone stated that in a post a couple of weeks ago.
The other reason to go with a 4bbl tbi w/ the delphi's is that the unit also uses progressive linkage, which of course is a good thing given a way to tune it in. Maybe a tps % toggle to the external injector driver?
Also, the delphis use a side mount connector and no black caps, just for reference
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I ran one of these 4bbl throttle bodies on my 350 when it was still TBI for about 2 months, but I only used two injectors since they were 65lb and plenty for my bolt on 350. It worked great, but I was at the point where I needed some tuning in order to revv in the higher RPMs so I ditched it for a carb and added some more goodies to my engine. I actually still have the Throttle body, I tried to sell it for like $200 a while ago and nobody wanted it. I would defenetly reccomend it to anyone who is building anything bigger than a 305 and keeping it TBI.
Engine: LO3;383tpi
Terrell351
06-13-2021 01:13 PM
mdtoren
08-16-2015 05:45 PM
