Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
How much will the Accel/LPE Base help my car?
Old Mar 18, 2001 | 06:07 PM
Dan87IROC-Z's Avatar
I decided to order one with the GP that is currently going, how much do you guys think this should help my car? It definetly feels like it needs more intake with my new cam. I don't have the money for heads and I think that with my ported plenum that the base should do more than the runners.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.625" 10 Bolt with 3.42s soon to come!
Old Mar 18, 2001 | 11:52 PM
shawn87gta's Avatar
I asked the vendor specifically if the Accel unit will outflow the stock base. He told me the only stock bases he has seen flow as much as the Accel were ported then extrude honed. Extrude honing costs more than the Accel base GP price - these were done for a racer that had to use stock components. How much of a difference it will make depends on the extent of your mod's, but with the hot cam you want all the extra air flow you can get. Plus once the base is installed the upper induction is easy to upgrade later when money/time allows. I'm not trying to sell you on it - we have plenty of participants on the GP already. I'm just sharing what I've gathered from researching the merits of the aftermarket base intakes myself. Other members of thirdgen have also told me there is a noticeable difference upgrading from the stock intake. The Accel can be ported for even more airflow if needed - mine will be!
Hope this helps,
Shawn
Old Mar 19, 2001 | 04:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Go for it Dan, replacing the intake manifold will help you for sure.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 20, 2001 | 05:35 PM
Does anyone else have anything to say, or any ET numbers before and after an intake swap?
L98 TPI 350 (5.7L)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Mar 21, 2001 | 10:36 AM
Beefy89's Avatar
I don't have any numbers,but a friend of mines dad is an engineer at SLP,and he thinks that the runners are the biggest restriction on the intake system.I saw an interesting post a couple of weeks ago where someone siamesed a stock base.I'm going to give that a try along with a set of aftermarket runners.
We need Perry Mason
Old Mar 22, 2001 | 11:07 PM
Jas89TTA's Avatar
I would get it. (I Did) I am installing the LT4 Hotcam in my 87 Trans Am and wanted a better intake to handle the camshaft.
Old Mar 22, 2001 | 11:26 PM
RARE-ROC-Z's Avatar
what is the price on the manifold GP.. and isnt it the edelbrock manifold ported and polished? thanks..
and i know for a fact that the manifold is the second most restrictive part of the LTR setup.. the runners being first.
and how long is the GP running for? thanks
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Mar 22, 2001 | 11:46 PM
Kevin91Z's Avatar
No, its the TPIS intake that is ported and polished. The Edelbrock and Accel intakes are as cast.
Old Mar 23, 2001 | 04:27 PM
The GP purchase price is $300. It regularly sells for $517 in Jegs.
L98 TPI 350 (5.7L)
Old Mar 25, 2001 | 01:30 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
300.00 is a great price for that manifold. I paid 500.00 for mine last year. Sorry.. I dont have any before and after results to share. My 406 is still on the stand.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
1992rs/ss
Jan 31, 2025 05:10 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Linson
Aug 21, 2015 02:12 PM
89-S-dime
Aug 12, 2015 11:57 AM
Fronzizzle
Aug 9, 2015 01:15 PM
