Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Engine Compartment Temp
Old Oct 26, 2001 | 09:55 AM
pullse's Avatar
I own a 88 Trans Am GTA and, as you all probably know, it gets pretty damn hot in the engine compartment over long trips, especially in the summer. Is there anything you can do to get some extra air circulating under there? Any opinions are great!
Old Oct 26, 2001 | 10:01 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
try removing the rubber seal along the back of the hood, thats a high pressure area and you'll get a lot of cool air in there...
-=-Mike
Old Oct 28, 2001 | 02:07 PM
colinfinkle's Avatar
What do you care about the air in the engine department conditions? If it the air for the engine go to a cold air setup.
But a popular technique I know of are ceramic coat or wrap the headers with some sort of insulator.
Of course the radiator is supplying all the hot air that your engine doesnt need. Cowls are nice, scoops are better. But, what are you wanting to cool off?
Colin Finkle
87 Sport Coupe Camaro, 5.0 L V8
My Car Craft in/out list:
In: Buying my project Camaro and being the first F-body in High School.
Out: While it is being upgraded 6 V6 F-bodies bodies show up!
Out: Looking like a pazie a** follower.
In: Being the only panzie a** with an 8 under the hood!!!
Old Oct 28, 2001 | 06:38 PM
pullse's Avatar
I'm looking to get some cooler air inside the engine compartment, only because I personally don't like it being so damn hot under there. (Please don't be such a wise guy when replying BTW).
PS. Why would you want to be a panzie a** in the first place?
Old Oct 28, 2001 | 07:02 PM
breathment's Avatar
well read ALL his sig. and it makes since.
Buy some ceramic coated headers, put in a 160* therm. get a cat back so the exhaust flows better.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 28, 2001 | 08:05 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
After I installed my coated headers most of the engine compartment heat was gone, just something to consider.
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated)1 3/4 SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,ES LCA and Panhard bushings,free mods.
0-60 5.2s
Track Time
60' 2.049
E.T. 14.14@96.7MPH (2270 FT)
13.76@99.4MPH corrected
Old Oct 28, 2001 | 08:38 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I'd leave that rubber under the rear hood. Water on top of your distributor is not a good thing. Perhaps get a cowl hood, let the heat escape out the back, high pressure area.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 28, 2001 | 08:45 PM
breathment's Avatar
what about removing the under hood insulation? since the stock hoods have the vents in them. might alow for a little more air flow
- David
Old Oct 29, 2001 | 04:02 PM
Wise guy? Me?
Well I was going to tell you about this company that I found called Swain Technologies (www.swaintech.com). They are way to expensive and are for race engines, but I like the idea of an engine not needing to radiate any heat, what so ever.
Oh well, no appreciation.
Colin Finkle
[This message has been edited by colinfinkle (edited October 29, 2001).]
Old Oct 29, 2001 | 07:26 PM
JETHROIROC's Avatar
Hmmm....won't radiate ANY heat? You must have discovered the perfect engine insulators and coatings that convert all energy from combustion into work and remove frictional losses entirely.
These coatings will REDUCE the amount of heat from combustion lost and improve the efficiency of an engine, but not eliminate it. The engine will still dissipate some heat. No doubt, however, the difference is noticeable.
Old Oct 30, 2001 | 01:44 AM
AudioDEO's Avatar
Car: 89 Formula 350
Engine: a Big one
Transmission: I dont keep them long.
ok what i did was remove the slot cover on the back of my hood 89 formula then put in 160 temp thermostat. then put a by pass on my fans where they stay running when the ignition is in the on position.
hottest temps under hard hard running conditions and then sitting for a while 190 most of the time it stays alittle over 160 the car used to run at 220 constantly and then after the motor work it would run around 240 ouch... but all this stuff fixed it great. the fans made the biggest difference though but all tegether make for one cool running motor....
Old Oct 30, 2001 | 02:12 AM
Omar's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Rob P:
I'd leave that rubber under the rear hood. Water on top of your distributor is not a good thing. Perhaps get a cowl hood, let the heat escape out the back, high pressure area.</font>
I have been down that road before. Rob is right, bad advice to remove that seal.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Oct 30, 2001 | 03:27 PM
<font face="Verdana, Arial" size="2">Originally posted by AudioDEO:
then put a by pass on my fans where they stay running when the ignition is in the on position.</font>
What did you connect the fan to? And was it tough to do?
Colin Finkle
Old Oct 30, 2001 | 03:39 PM
mtccl's Avatar
Find your fan temp sensor on the lower right of the engine down near the 3 sparkplug back. Easier to get to from underneath the car. Splice a wire into that switch's wire and run it into the passenger compartment. Hook that wire to a on/off rocker type switch. Now ground the other terminal of the new on/off rocker switch to the body. Somewhere under the dash. Now you have control over one of your fans. You can turn it on whenever you want. I leave mine on all the time when its warm outside.
87 TA, 305 TPI, Custom CAI, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler
"35 yr old helo pilot
with a cool new toy my 17 yr old son wants" The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
Old Oct 30, 2001 | 06:45 PM
AudioDEO's Avatar
Car: 89 Formula 350
Engine: a Big one
yea you can hook up a switch if you want that would be best in the winter but in Texas it never really gets cold so i went the cheesy way and just jumperd the power wire for the over to the switched wire so as long as the ignition wire has power the fans are on its the easyest way. but not the best way a switch is the better way.
italiano67
Dec 11, 2016 09:21 AM
Firebird sweden
Aug 16, 2015 05:02 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Randomtask2
Aug 13, 2015 01:57 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
