Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Best Spark Plugs
Old 05-11-2004, 01:38 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Best Spark Plugs
I have been using AC Delco's for a few years now, but am currently thinking about going to Bosch +4 plugs. I hear they are "suppose" to be better, but is there really that much difference between plugs?
Any opinions/suggestions would be appreciated.
Thank you!
Old 05-11-2004, 01:49 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Stay with Delco, maybe try the Delco Rapidfires
Old 05-11-2004, 04:34 PM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Lock at the top right of this page and click search. This is so old as a subject!
Si.
ps. ac delco or ngk are what you want!
Old 05-11-2004, 04:54 PM
TransAmman87's Avatar
Car: 90 Trans Am
I asked this question awhile back. I got the Platinum 4's 3 weeks ago, installed them, and my car wouldn't run right. I had a mechanic take them out and they looked like they were already wore out. Look at the posting "Bosch Lied". I started this thread and you'll see why.
Old 05-11-2004, 05:26 PM
Thanks for the input everyone.
TransAmman87, sorry to hear about all the trouble you had... I'm not going to risk puttin the +4's in my car now!
I did read about some people putting regular AC Delco plugs in their car and others putting RapidFires in their cars. Is there a noticeable gain by going with the RapidFires over the regular AC Delco plugs?
Old 05-11-2004, 09:38 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
I could not tell a difference between the regular AC Delcos and the Rapid Fires. The rapid fires cost more. I did notice a difference with the Accel U Groove Header Plugs I used last time though.
Old 05-11-2004, 11:00 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
I'm using Champion Copper Plus. No problems.
Old 05-12-2004, 01:30 PM
The heatrange of the Rapidfire is wider than regular Delco's, therefore they withstand fouling better, but you only notice the difference when a (regular) plug foules!(no powergains or so!!).
Old 05-13-2004, 01:30 AM
iroc22's Avatar
Change your plugs every 10,000. You'll get the most performance gains.
Old 05-13-2004, 11:56 AM
5.0Camaro's Avatar
Car: 1991 camaro Z28
NGK makes some good stuff, thats what the 4th gens seem to be using and over on the ls1tech.com board and those guys over there seem to really know there stuff.
Old 05-13-2004, 03:54 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
NGK Iridium plugs went in late last year, haven't driven it since, so can't make any pro/con comments yet. Expensive though.
Old 05-14-2004, 12:45 AM
iroc22's Avatar
There's something to remember when buying spark plugs: the harder the metal the less conductive the spark energy transfer is. So you get a slower, smaller spark with the harder metals. Iridium is the hardest, followed by Platinum and last is copper. The harder metals outlast the softer ones, but you lose performance.
Something to keep in mind anyway.
Old 05-14-2004, 02:00 AM
age
age's Avatar
Car: 1992 Z28 1LE
iroc22: but what about their claims that with a smaller center electrode, less voltage is required to jump the gap. Wouldn't that therefore "even" things out when compared to the material being less conductive than copper? I checked out the NGK website a while back, and was also reading about how they had redesigned the Iridium spark plugs itself to prevent fouling. What are your thoughts on those?
iroc22, I'm asking these questions out of a serious, learning inquiry. I'm not a believer or "gimmick" plugs, but I can't help but wonder that as time grows on us, so would technology.
Old 05-17-2004, 05:33 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Plugs are plugs, it's plain and simple. As long as you get the end gap and heat range right according to your engines compression ratio, none of those fancy platinum or iridium plugs will give you any extra hp, they'll just last longer. I know because of a friend who's been on the dyno with his race car over a 1000 times, has found this out to be true.
Old 05-17-2004, 11:22 PM
iroc22's Avatar
Well thats a viable argument, but I would tend to think that according to V=IR, that if you lowered the voltage, the amount of amperage flowing through is less. The ohms usually remain constant within sparking processes and the resistor size physically is usually the same as well. I'll still stick with my theory that copper can conduct better and will produce better power when optimized (not worn out).
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
db057
04-28-2019 07:45 AM
Jlanz55
09-09-2015 09:09 AM
90formulaVortec
09-08-2015 12:42 AM
89 formula TPI
09-07-2015 11:06 AM
Quick Reply: Best Spark Plugs
