ebay mini starters
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
ebay mini starters
anyone messed with them? they are ALL lower in price then summit or jegs. this ad in particular has me intrigued. seems like they really took the time to inform their clientel.
http://cgi.ebay.com/ebaymotors/CHEVY...QQcmdZViewItem
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Re: ebay mini starters
I have one on my car, that ebay guy is a local speedshop. It turns over my 11:1 383 easily, havnt had a heat soak issue with it, you can position it a few ways, it came with alot of shims, for the block and the starter motor to big aluminum block.
Their ebay ads are all rediculous. they are a pretty decent company, they machine shop has some high prices. Ive bought a starter, a cheap Hei distributor, I used a differnt coil and control module on it. Ive even used there cheap stainless roller rockers, (comp knock offs) I havent any problems with anything.
Kevin
Kevin
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
ive got a similar one, 3hp, spins my 408 like its nothing, only issues i had was that i had to shim the heck out of it to make it engage the flywheel, almost 3/8", and the screws that hold it together, that you loosen to rotate the housing, were sooo f-ing tight i could hardly get them off, had to use an impact driver. Other than that, no problems
Engine: 7.0L
how much does your starter weigh? i think i'm gonna give 'em a try. i don't have a whole lot of cubes, but i'm about to bump the c/r to 11:1
Car: 86 Trans Am
, i never threw mine on a scale, but that sounds about right Member
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
i bought one too since i had to get it in order to fit my LT headers, and havent had problems with it. is the cheapest i found and decided to try it, no regrets.
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
bringing this back from the dead, what particular seller im wondering or item were these guys talking about im looking into another ebay company just thought i check first
Car: 92 GTA
Transmission: 5 Speed
Axle/Gears: 3.27 posi
I bought one from a store called gearhead enterprises, or something it was like a year ago. It literally lasted about 5 starts then it started running on its own and it would not even let power reach anything but the solenoid. It was a procomp unit biggest piece of crap ever. Then I returned it and tried to get a replacement or a refund and they keep giving me the run around. I finally gave up. Havent bought another one yet.
http://cgi.ebay.com/ebaymotors/3-HP-...Q5fAccessories
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I found a junkyard LT1 starter on ebay or $20 and it's still kickin just fine.
Car: 1986 Irocz
Axle/Gears: 3.25:1
I've had experience with a LOT of starters.
By far the best performance I have seen from a starter has been from a CSI (now CSR) unit I bought in 1998 from Summit.
This one: http://www.summitracing.com/parts/CSI-100U/
and as it says, is over $200.00
This year I have seen what looks to be the exact same starter for sale under the "Renegade" name for only $87.84 - part# REN.87001
I saw this listed in an engine builder's catalog called "Motorville" from Lexena KS.
That said, the rated starting capability and speed for any starter will go up significantly with the use of an ignition kill switch. This kills the spark for turning the engine easier during start. Once engine is up to speed, turn the spark back on. This is most useful for hot starting. Without a kill-switch I think any design of starter can have problems due to overload or kickback.
The starter I bought mentioned above weighs 6 lbs, and is fully clockable.
I would definitely buy this model again.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
The guy with the last name White sells durable units. I have plenty of friends using them. No complaints.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
you can always get the ricky race unit from GM $130 (5 to 6lbs)
pemnt magt style(you could drop in in your pocket!)
spun my 11.1 383 like it was nothing!
it's also made to spin Big Blocks..and it's a GM Part
it's going on the new 427
I got mine from a ebay store,KMJ performance,Paid 70$ had it two years with no problems.
http://www.kmjent.com/cart/product.p...4736486&page=1
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I don't think that's the brand I got, but I did use a cheapy ebay mini starter....lasted about two weeks then I thru it in the trash. If it's cheap price, then it's probably cheap product. Put a new stock starter on, no problems since.
thats why i stick with the real GM PP parts..
will always work and last!
bolt in! headers will not Kill it..lots of room!. and you get to drop over
15lbs off the front of the car.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Yeah, I had 2 Ebay mini starters go out on me... I finally got an lt1 starter with a lifetime warranty and haven't looked back.
