Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Ignition Control Module
Old Nov 27, 2011 | 08:13 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Will these Ignition Control Modules do anything for my crossfire or be the same as stock ?
http://www.summitracing.com/parts/PNX-D2001/
http://www.summitracing.com/parts/DUI-000333/
http://www.summitracing.com/parts/ACC-35363/
Old Nov 27, 2011 | 03:24 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Ignition Control Module
if the rest of your ignition system and engine are otherwise stock, you won't notice a difference. grab a new ac delco unit and spend the extra cash elsewhere
Old Nov 27, 2011 | 03:28 PM
KITT1983's Avatar
I have a MSD ignition coil #8225, MSD sparkplug wires, MSD cap and rotor already installed.
Old Nov 27, 2011 | 09:24 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
what's done to the engine? tuning? what are you revving to?
Old Nov 28, 2011 | 03:06 PM
zee28's Avatar
Car: 86 iroc
I know most here hate accel but I have had their module,cap,plugs,wires and super coil for 13 years now with no problems.Is it faster,no more reliable? I would say yes in my case.
Old Nov 29, 2011 | 04:00 PM
frederzick's Avatar
Car: 1991 Camaro Z-28
Transmission: Automatic
Axle/Gears: 2.73:1
I ran the Accel cap, rotor, module, and coil after my initial module went up. The new module only lasted for a few years, after that I went back to all AC Delco stock. I was rather disappointed especially since my car isn't daily driven, heck it barely get's 1000 miles put on it a year. Recently though I have upgraded the coil again to a MSD Streetfire along with installing one of the MSD Streetfire ignition boxes (used the MSD harness to just plug right into stock harness, very nice), waiting on injectors to see just how well these two improve fuel economy and/or performance.
Old Dec 27, 2011 | 07:30 AM
frederzick's Avatar
Axle/Gears: 2.73:1
After now having the injectors installed, for well over a month, I think the only noticeable improvement has been starting and maybe a little bump in fuel economy. I must note though, I am now waiting on a new set of spark plug wires, because I now have static on my radio that I have narrowed down to the MSD box being the culprit. I even installed there inline filter, which helped, but I believe the final piece of the puzzle is replacing the stock wires with a good set of spiral or helically wound wires. I also want to note that when I ran the Accel ignition parts the car did seem to run better than stock, when they were working that is.
Old Jan 1, 2012 | 09:17 AM
KITT1983's Avatar
the motor is a stock 305 CFI
Old Jan 1, 2012 | 10:23 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
After the issues I kept having with Accel ICM's, I stay with stock now. I have aftermarket everything else, but I will never go with an aftermarket module again if I can help it.
Old Jan 3, 2012 | 10:34 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
I've ran Accel modules in my old 83 CFI Z28, as well as one in my 86 currently, which I tried out a Speedway (Unilite) module as well. Never had ANY issues.
All were an improvement over the OEM units IMHO. Each time I did it when I upgraded the entire system, though- plugs, wires, cap, rotor, coil.
Old Jan 3, 2012 | 11:07 AM
dfarr67's Avatar
I tried a couple 'performance' modules left me stranded- use oem.
Old Jan 5, 2012 | 03:18 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
A common mistake people make when switching out modules- OEM or otherwise, is to not use enough or any of the grease on the bottom side of the module. This helps with heat transfer, and prevents cooking the module.
Old Jan 5, 2012 | 07:47 PM
KITT1983's Avatar
I recommend this stuff from radio shack
http://www.radioshack.com/product/in...ductId=2102858
(6 of 6 customers found this review helpful)
5.0good product
By greg
from staten island, n.y.
About Me Casual User
Pros
  • Consistent Performance
  • Prevent breakdown
Cons
  • No problem
Best Uses
  • Ignition modules
Comments about RadioShack Heat Sink Grease (6g):
good for ignition modules on cars to prevent burning out of new part.
  • Primary use:
  • Personal
Bottom Line: Yes, I would recommend this to a friend
Old Jan 7, 2012 | 10:44 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Honestly I don't see a point to upgrading a module since the stock ones are typically variable dwell anyway. I haven't found ignition upgrades to be that fruitful anyway so unless you're going to put in a multi-spark system or improve high rpm reliability you should probably just save your money.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
