Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
icon pistons? good, bad?
Old 05-10-2013, 09:47 PM
kevin j's Avatar
Car: 1986 firebird
Engine: 355's being built it be sweet yo!
Transmission: th400 short tail
Axle/Gears: 4.11
Im kinda on a budget and really I'm just looking for the biggest bang for my buck at the correct CR. I found icon pistons at the right price and I was wondering what the people of thirdgen thought. Any advice is well appreciated because this is my first engine build
Old 05-11-2013, 06:52 AM
1gary's Avatar
Re: icon pistons? good, bad?
Hey Kevin.What's your intended use??. What is the SCR??. Plan on a shot of nitrous??. How big of a shot of that if so??.
Old 05-11-2013, 01:55 PM
kevin j's Avatar
Car: 1986 firebird
Axle/Gears: 4.11
Mild drag. And I'm not using nitrous until I get the parts for a stroker. I'm also staying NA until then so I was looking for something with a little dome to get me too that 11:1
Old 05-12-2013, 07:20 AM
1gary's Avatar
Kevin what your buying is a mid quality piston that is alittle better than cast but not really forged. They have a feature built into them with off-set pins to limit cold piston slap. Standard ring sizes not metric which I like. Pin sizes that press fit pins is ok.
At 11.1 your way heavy for any pump gas use..............
Old 05-13-2013, 09:59 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Woudl 11.1 really be that much ahrder to run on pump gas than 10.5? My 10.5 runs on 89 with no pinging, I would think it could run 91 or 93 at 11.1
Old 05-13-2013, 12:21 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
How can they advertise as forged if they are cast?
Old 05-14-2013, 01:02 PM
1gary's Avatar
Check your math.....
Old 05-14-2013, 01:04 PM
1gary's Avatar
They are not a full forging.
Old 05-14-2013, 07:59 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
What's a partial forged piston? Hypers? Please elaborate.
Old 05-14-2013, 09:37 PM
1gary's Avatar
It almost sounds inconceivable,but I-Con told us the top portion is forged only.
Old 05-15-2013, 03:52 AM
1gary's Avatar
You'll see on this chart a final bore/hone size that is very much like forged pistons:
Old 05-15-2013, 10:12 AM
That make sense for their "forged head relief" line of pistons. Those are their cheaper line of pistons. I'm guessing the ones they list as "forged" only are normal forged pistons. Like the IC604.
Old 11-20-2015, 09:39 AM
ICON Pistons's Avatar
Although this post is over two years old ICON would like to state that ALL ICON pistons are 100% forged, both the Premium 2618 alloy and FHR 4032 alloy. The FHR that once stood for Forged Head Relief was referring to the valve pockets as they are formed in the forging die unlike the Premium series that are machined in. We now state the FHR as Formed Head Relief as to not confuse customers that only the top is forged, which of course cannot be done. The forged FHR series is an excellent choice for street performance that can be used with mild boost (15lbs) or nitrous (250hp). For more serious applications it is recommended to use the Premium 2618 alloy series.
Old 11-20-2015, 01:52 PM
Originally Posted by ICON Pistons
Although is post is over two years old ICON would like to state that ALL ICON pistons are 100% forged, both the Premium 2618 alloy and FHR 4032 alloy. The FHR that once stood for Forged Head Relief was referring to the valve pockets as they are formed in the forging die unlike the Premium series that are machined in. We now state the FHR as Formed Head Relief as to not confuse customers that only the top is forged, which of course cannot be done. The forged FHR series is an excellent choice for street performance that can be used with mild boost (15lbs) or nitrous (250hp). For more serious applications it is recommended to use the Premium 2618 alloy series.
Good info to have. I like the ones I'm running now and will probably buy a set on my next build too.
Frozer!!!
01-19-2024 04:55 PM
86IROC112
04-09-2016 10:20 PM
BBSDesigns
08-11-2015 07:39 PM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
Quick Reply: icon pistons? good, bad?
