Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
what kind of timing does the HSR like?
Old Jun 29, 2005 | 01:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
as subject asks.. whats the best timing for a hsr with my kinda mods? should i stick to +6 or take it a little further?
Old Jun 29, 2005 | 07:24 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Leave the base timing at 6 or 8 and compensate for it in the ecm.
Then u need to do track time and dyno time to find out what your combo likes.
Heads and combustion chamber design to far more to influence timing than the intake(within reason)
later
Jeremy
Old Jun 29, 2005 | 10:43 AM
klumb15's Avatar
i'm running 12* advanced right now, and I think I gotta go more with this new cam....my mechanic said I might be running upwards of almost 20 once i get the 02 sensor in and evyerhting tuned right...its just one of those things you gotta play with....he said the best way to set it is, turn it till you get some popping and then back it off a couple degrees, and plug the ecm back in....then it keeps you on the edge of performance...
Old Jun 29, 2005 | 11:17 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Until the ECM hears the knock you didn't hear and yanks a bunch of timing out.
Old Jun 29, 2005 | 12:54 PM
klumb15's Avatar
well maybe it did, but before i had the base timing at 6* and it ran okay, then we disconnected the ecm timing again and brought it to like 12 or so advanced, and it runs awesome with the base timing at that....so i'm just saying playing with the timing makes a huge difference...
Old Jun 29, 2005 | 04:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks. im having it dynod next month so i just need this to tide me over till then.
Old Jun 29, 2005 | 08:27 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
I have to run my timing at 0* to aviod detonation. The lack of an EGR and all the advance the hypertech chip throws at it are the reason. I should get a custom chip so I can set it at 6*.
Old Jul 3, 2005 | 03:23 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have mine set to 12 with 12 set in the prom on my stock 305. runs pretty good and no detonation.
Old Jul 6, 2005 | 04:25 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i left mine a 6* and seems to work good but i have some fine tunning to do so we will see
Old Jul 6, 2005 | 11:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
whats the stock timing in the prom?
Old Jul 7, 2005 | 12:38 AM
Zepher's Avatar
I believe it was 6*.
Old Jul 7, 2005 | 12:59 AM
smokefan's Avatar
yes stock timing in the prom is 6*
italiano67
Dec 11, 2016 09:21 AM
ASE doc
Aug 25, 2015 09:14 AM
86IROC112
Aug 17, 2015 07:57 PM
Randomtask2
Aug 13, 2015 01:57 AM
novaderrik
Aug 10, 2015 12:44 PM
