Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
<--- engine build help
Old Aug 24, 2005 | 05:36 PM
Gecz28's Avatar
Car: 88 iroc vert
lookin for options on EFI. which is best for a "lower" rpm, 5500-5800? ill rarely see 6000.
what combos would you run for 475-500hp/trq?? naturally aspirated.
i know there is the HSR and Super Ram, what are some other types?
id like to do something a bit different?
Old Aug 24, 2005 | 05:55 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
what heads will you be running?
Old Aug 24, 2005 | 06:25 PM
Gecz28's Avatar
Car: 88 iroc vert
none at the moment. i would like to get some ideas on what heads, cam and injection ppl would suggest.
Old Aug 25, 2005 | 10:26 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I think a Super Ram, Ram Jet, HSR or a converted carb manifold could work with the right cam. Maybe a 220/224 or 224/230 cam?
Old Aug 25, 2005 | 01:43 PM
c4boom's Avatar
Engine: l98 and lo5
to get that type of power out of a small block NA will be tough. i would look into a set of afr 195s and a HSR or super ram
Old Aug 25, 2005 | 06:15 PM
Z69's Avatar
Z69
To get close to 500ftlbs.
A 383,10.5 to 11 cr. 195-200cc heads, 224-230 @.050 on the intake cam.
And any of the listed intakes. The SR will favor torque, but the others may be easier to launch and be faster.
You could check out my web site or do a search here on First Intake for something different.
Old Aug 26, 2005 | 12:58 PM
Tibo's Avatar
Car: 1991 Z28 Vert
What kind of car will it be? Have you driven other cars of varrying power levels? A 300-400 Hp car is a lot of fun to drive on the street. But 500? You really don't need that for a street only car. You want it (me too), but don't need it. You would be hard pressed to attain that low end power with a N/A car.
Old Aug 26, 2005 | 05:21 PM
Gecz28's Avatar
Car: 88 iroc vert
its a iroc vert. 8pt cage sfc's as of now. it will have all new susp., bigger brakes, ect.
yeah 500 probably is a bit extreme
i may take it to the drags a few times, but not a lot. id rather have it set up for "road racing" but on the street.
i have driven a few cars with maybe like a 100 hp difference, 300 and 400 approx?
i seen an article in a CHP(i think), it was a 406 with vortec heads that made like 440hp-525ft/lbs. something along those ratings would be better for the street? huh?
it was carbed, but maybe adding EFI to that set up would maybe bump the power a bit too?
Old Aug 28, 2005 | 02:43 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Here is a setup for high 11's I have seen. 383, AFR heads, Lingenfelter(219/219) or GM Hot Cam, with SuperRam or HSR. HSR had the Hot Cam, AFR heads, 383 running 10.5 running 11.73 in the quarter. The SuperRam had a 383, Lingenfelter cam, AFR 195cc heads running 11.9 quarter miles. I have the 180 cc AFR heads making around 450 to 470 ft lbs of torque with the HSR and 425hp and I can add more hp with bigger throttle body, bigger header primaries, etc.
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
