engine code 43?
Old Oct 1, 2002 | 01:15 PM
92 z28's Avatar
engine code 43?
hey, i noticed my "service engine soon" light pop on today. so i tested the ecm, and i got code 43, the pamphlet i got from autozone does not have the definition of code 43 in the book. does anybody have the definition of this code? let me know. thanks.
Dozer80464@aol.com
Old Oct 1, 2002 | 01:20 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
No but I can find out.
>anyone who says search has to give me a dollar!!!!!
This is what I'm doing
www.google.com
Search for GM engine code 43
>look through to many answers
BRB
Old Oct 1, 2002 | 01:23 PM
http://www.flash.net/~abilling/gmcodes.htm
K he says
43 Electronic Spark Timing (EST) Circuit - low voltage detected
Had to be a thirdgen site! :rockon:
Oh yeah try the tech/engine forum. Those people know a sh!tload.
>hack at it!!!
Old Oct 1, 2002 | 01:35 PM
92 z28's Avatar
it says its the Electronic Spark Timing (EST) Circuit - low voltage detected ... what the hell is that?
Old Oct 1, 2002 | 02:15 PM
KlayBuRn's Avatar
Check your timing...
Old Oct 1, 2002 | 02:26 PM
92 z28's Avatar
how do i check timing?
Old Oct 1, 2002 | 03:11 PM
KlayBuRn's Avatar
You need a timing light...
what motor you got? and tpi, tbi, carb?
Old Oct 1, 2002 | 03:38 PM
92 z28's Avatar
its a 305 tbi... please be more detailed cause im not that knowledged about the electrical system. thaks in advanced!
Old Oct 1, 2002 | 04:06 PM
OH BTW some of these error codes are wrong so correct me if you know.
This site says different
>http://www.corvetteradios.com/Troubl...eECMCodes.html
43 Knock Sensor Circuit
Hold on let me get the book.
Old Oct 1, 2002 | 04:13 PM
92 z28's Avatar
basically i need to know what to do..... and i dont know what or where the knock sensor is located.
Old Oct 1, 2002 | 04:18 PM
K this is right out of the book.
43 (four flashes, pause, three flashes <font color=blue><i>no shat book!</font></i>)
Electronic Spark Control (ESC) system
Problem cause:
Check wire leading to the ECM terminal L
Check the wireing connector at the ESC controller and at the ECM
Check wire from the Knock sensor to ESC controller; if necessary, reroute it away from other wires such as spark plug, ext.
Well now that I remember I got that error code also. It didnt seem to affect anything except the check engine light. So I'll I did was the last step <font color=red>reroute it away from other wires such as spark plug, ext.</font> That seemed to get rid of one of the codes. But now I have to deal with these errors.
22 TPS sircuit
23 M/C soenoid circuit
24 VSS circuit
The only time it affects it is if I really get on the gas for a while. Then it comes on and adjusts the timing is some fked up manner and takes away some horse power. Great..... Keep in mind if you want to reset the codes to nothing there should be a small black fuse box by the battery. Pull out the fuse for about 20 seconds or so.
>BTW I"m searching google.com for phrases and keywords. This is how you use the internet to find anything you want. I'll be posting what I find here. .........
>Electronic spark control (ESC) -- The computer system equipped with a knock sensor that can retard spark advance if necessary to eliminate spark knock.
>The ESC retard signal has been on for too long or the system has failed a functional check.
>Most say that it is a bad sensor and if you replace that it is a first step into fixing the problem.
http://www.syty.org/diagnostics.html
Old Oct 1, 2002 | 04:25 PM
Hey what kind of car do you drive?
Old Oct 1, 2002 | 04:45 PM
92 z28's Avatar
92 camaro 305 tbi
Old Oct 1, 2002 | 05:01 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
Originally posted by 92 z28
92 camaro 305 tbi
aha! phony! so you drive an RS then, why is your name 92 Z28! j/k!
Old Oct 1, 2002 | 05:05 PM
92 z28's Avatar
itll have a 383 eventually, dont matter.. but now i gotta fix this code 43 problem.
Old Oct 1, 2002 | 07:26 PM
LeftTurn1LE's Avatar
I didn't say a word.
Old Oct 1, 2002 | 09:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
