Check out my new ride... answer my questions please.
Old Nov 6, 2002 | 04:00 PM
1989 2.8L Bird's Avatar
I bought a 1984 trans am from a friend for $800 dollars. The car overall is in pretty good shape. It has no rust anywhere, and the interior is good except the front seats and console cover.
I know that the car needs new guages, brakes at some point, a windshield, and an air inlet on the passenger side. It also probably needs a blower motor and there is something wrong with the heater valve. There is an exhaust leak in the area. It needs the usual tune up and I need to adjust or replace the TV cable too.
The previous owner scraped a guard rail, which caused the left side to have a few dents in the front fender, a scrape in the front of the door that is pressed in, and a slightly bent in rear fender. These scratches in no way affect the functionality of the car. There are three pictures below of the car. It has an L69 305 carbed in it.
here are my questions:
1) Is this car worth 800?
2) How would you fix my driver side and how much would it cost.
3) What do I need to do if I have a bad heater valve?
Attached Thumbnails Check out my new ride... answer my questions please.-mvc-002s.jpg
Old Nov 6, 2002 | 04:02 PM
another
Attached Thumbnails Check out my new ride... answer my questions please.-mvc-010s.jpg
Old Nov 6, 2002 | 04:03 PM
engine... not as bad as it looks... the picture was taken at night.
Attached Thumbnails Check out my new ride... answer my questions please.-mvc-011s.jpg
Old Nov 6, 2002 | 04:04 PM
im getting a car cover soon...
Attached Thumbnails Check out my new ride... answer my questions please.-mvc-011s2-1-.jpg
Old Nov 6, 2002 | 04:16 PM
Pacer's Avatar
Car: 82 Camaro Pace Car & 1989 IROC
Engine: LG4. & 350 TPI
Transmission: 200C
Hey, 1989 2.8L Bird, welcome, you're new.
I'm afraid to say that the car is probably better suited for parts than driving. Sounds like there's lots of work ahead to make it trully roadworthy. How many hidden repairs needed ? Snow won't speed up the work either. Cut your losses now and see if you can resell it whole. I'm not sure what kind of market there is in NH for parts off an '84. If you can drive the car now, as is , go for it and then walk away if it dies.
It's gonna take lotsa time and money. Good luck.
Patience is a virtue.
Pacer...
Old Nov 6, 2002 | 10:25 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I wouldn't pay $800 for that... I'd pay maybe $200 and sell it for parts. But if you want a project, you got it
Old Nov 6, 2002 | 10:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I wouldn't have paid more than $500 I would say, but ehh, just depends on what you want really.
If there is no rust, but considering where it's from I doubt that, then good deal.
I've seen worse deals before.
Old Nov 7, 2002 | 06:28 PM
MdFormula350's Avatar
i am definitely with these guys in saying its better for parts, but if you want to tackle a project you got one.... 800 is alitte high though..
Old Nov 7, 2002 | 06:46 PM
Trans Am's Avatar
Holy **** ,That is my cars twin.But mine was the evil twin.
Mine is a 305,but the interior and exterior are identical.
Plus mines in a lot better shape
The only dif now is the out side is black
Old Nov 8, 2002 | 10:29 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Yep, no way i'd pay 800 for that. That's way to high. I'd say $500 max.
Old Nov 8, 2002 | 10:59 AM
Steve89GTA's Avatar
wow, does that motor run?
Good luck with your new car dude!
Old Nov 19, 2002 | 11:51 AM
YES, and damn decent too... its in the dark and it looks like **** but its really pretty decent...
Old Nov 19, 2002 | 06:34 PM
berlinetta85's Avatar
Don't sweat the others brother.... you've got a decent ride. Here is what I would do if I were you.
Take some "Simple Green" and a brush to that engine and clean that Shiz-nit out!!! Doesn't have to be show car quality but will diefinitely help while tinkering under the hood and be a little more presentable.
School yourself up on body work and prepping and do it all yourself and then take it in for painting, you'll save hundreds by doing that.
Now if you want to upgrade the car here and there. I'd start with the suspension for better handling... all the while keeping an eye out for a decent engine you can build up for it. That way you can still drive the car untill the new motor is ready.
Sounds simple yes.... but it will take a while though... just do things one step at a time.
Old Nov 19, 2002 | 09:50 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
I thought that white one was a car cover?
Old Nov 20, 2002 | 04:25 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Car looks great man! I know how it is starting out with a project car, and mine still is....until i take the transmission out of my 83 Z28 parts car to put in my SC. I am planning on putting a 350 in mine, it is motorless now so check out the link in my sig for pics and info.
Old Nov 21, 2002 | 12:00 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Don't get discouraged. Only you know if $800.00 is more than you should of paid and really since you already paid it, it's too late to do anything about it. Seems like you want to do the work so here's my opinion.
1. Fix the exhaust. This effects gas mileage and the fumes can be deadly if they get inside.
2. Spray your engine with a degreaser, then power wash it. You need to see what you got there for future leaks, wires and repairs.
3. Not sure what you are calling the heater valve. If you mean the heater core that produces heat, you will need that in New Hampshire. This is called a creature comfort and you want to be warm, don't you? Is it snowing there already.
4. Make sure your car is running mechanically sound first before making it look pretty. The body looking good around a crap engine is stupid. Do the reverse - engine then body.
5. Fix your guages. If need be go to the junk yard and start swaping. The yards are a cheap way to get your car up to speed fast.
6. Once the mechanical is done, start preping the body yourself and you will save. Research a good body shop. If you plan to keep the car then don't cut corners in this area or you will be repainting in 2 years.
7. Set a timetable and goals that are realistic. If you stay on this site you will get lot's of ideas talking to other members.
Good luck.
Old Nov 21, 2002 | 01:48 AM
maksik7's Avatar
Is it just me, but that engine doesn't look like an L69 to me. As far as I know the L69 had dual intake ducts. Looks like a plain LG4, I may be wrong though.
Old Nov 21, 2002 | 10:19 AM
You know if you wanted to rod out the engine you have in there, I found this site that has a pretty decent way of doing it...
http://www.goingfaster.com/spo/325_h...chevrolet.html
325 HP is a pretty respectable amount of power for a daily driver.
But I would go along with 86 and get right on those things that are in need of repair ASAP... especially the heater core if that "is" what you are taking about. I did mine and it took a fair amount of time... also I'd have a friend help as an extra set of hands is very helpfull with that sort of fix.
Old Nov 21, 2002 | 10:22 AM
Oh and $800 is a decent price for a car in need of minor repair...
I picked up my formula for $1200 in roughly the same condition yours is in...
a little elbow grease and you'll have a hot rod you can enjoy
Old Nov 21, 2002 | 10:25 AM
85_ZED28's Avatar
Car: '85 Z28
are you sure its an L69?? I thought they all had the dual snorkel?
Old Nov 23, 2002 | 12:47 PM
sorry guys its the LG4... i made a mistake... when i said a heater valve, i ment the heat riser valve... my grandfather said you can take it out and replace it with something?
I found taillights for it for 15 bux plus shipping, cuz one is cracked... and i found a daytona style hood for 250, and im buying it because i LLOOOVE the daytona style hood... i know others dont agree, but that doesnt matter to me...
thanks for the help... keep writing
TOM
Old Nov 24, 2002 | 04:26 PM
MG86TA's Avatar
I think you have a potentially nice bird there.. You will feel much prouder of it if you complete it and make it look truely awesome Good luck! :rockon:
jklein337
Sep 19, 2018 06:23 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
