ram air hood pics please
Car: 89 Black GTA
Engine: 5.7 TPI
I am thinking about getting either this hood:
or this hood:
But I cant find a pic of the first hood on my GTA style front end. I hate the way the 90s front ends look. So, does anyone have a pic of this hood on my front end?
Brian
or this hood:
Brian
Car: 89 Black GTA
Engine: 5.7 TPI
thanks, but is that the first or second hood. I think it looks more like the second but in your pic it looks really nice. I might have to change my mind AGAIN.
Thanks again
Brian
Thanks again
Brian
I don't know anything about the hoods, but, that top Firebird is flat out gorgeous. I'm going to run out and get mine painted, pronto!! I didn't realize they made tubs of Vaseline big enough to dip a whole car!
BTW - the 90's front end is 80% of the reason I bought my car. I'm just sayin'...
Car: 89 Black GTA
Engine: 5.7 TPI
And ya, that paint job is flat out gorgeous.
Brian
Originally posted by 89blackGTA
I totally dig the fact that others like that front end. I just dont like it. I think mine is a little tougher looking were the 90s looks a little sleeker.
Brian
Brian
http://www.pnw3.org The main page has my car on it.
That is the first hood on a 1990 Firebird (flat nose, the sleek was only 91-92)
Car: 89 Black GTA
Engine: 5.7 TPI
Originally posted by scott's85T/A
redraif has the 2nd one you showed. It's suncoast creations.
Is this what you are looking for?
Brian
Car: 89 Black GTA
Engine: 5.7 TPI
Originally posted by nolanr0413
get a powerbuldge hood, too many people are starting to get ram air hoos for their car and they dont match the lines.
2. Our cars really dont breath that well, so a ram air would help ALOT
3. Do you have any pics of the powerbuldge?
Brian
NO the ASCD ram air isn't functional, But I did cut two holes on the inside of the hood to let air flow through.
The suncoast hood has a setup you can buy to make it work.
It's 2x the price of the ASCD if you get there airbox too.
Car: 89 Black GTA
Engine: 5.7 TPI
Brian
i am really debating on getting the ram air one hood!!
http://www.thirdgenresource.com/inc/pdetail?v=1&pid=461
very tempted...
very tempted...
Car: 1987 GTA
Transmission: 4L60e
Got anymore good shots of that bad boy? I have to decide between the RA I and II come Summer....and that looks incredible.
Also, look up the Reader's Rides and RCR. he has that hood I think
Car: 89 Black GTA
Engine: 5.7 TPI
Originally posted by 3.1EyeCandy
Brian
Car: 89 Black GTA
Engine: 5.7 TPI
aw c'mon now
it isn't THAT bad....I could have done it in paint
aw c'mon now
Brian
Car: 1987 GTA
Transmission: 4L60e
I know......just having fun man. You want a hooptified black version?....do it yourself cuz it took me 20 minutes to do a red one :lala:
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
here is the link to some of my pics....
http://community.webshots.com/user/paulstoy71
i have the interior gutted now changing interior color, carpet, console ,seats . power window kit
would post pics but havent got around to resize them to fit...
what is the best size to go with?????
Car: 89 Black GTA
Engine: 5.7 TPI
Originally posted by fun Pain
here is mine any questions.... does wonders for my body lines
Brian
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
the back of the ram ports are cut out, and the cowl for that matter for heat and digital tach and shift light, however the ram isn't made to the air cleaner so it doesn't function like a 4th gen, mainly because i plan on a D1-sc, it will such more air then a ram air (compression) will ever make
Car: 00 TA, 91 Formula, 89 RS
Brian
Brian
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Originally posted by FyreLance
Have you had 7 other hoods as well?
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I think there are a few of us that would appreciate some detailed pics of how much room there will be with this hood to make a Ram Air box.....
... hint hint, cough cough....
It looks to me like there will be enough room to make the box that Suncoast sells for their hood work.... and I think that GTAA has a box set up for their Ram Air hoods as well......
Well Matt , I kinda got the hint there,, I went and took some pics of mine down in the garage, there dark but you will get the idea.
I measured the inside clearance from the inside and you will get about 3" of room from this hood, but you will be lucky to get about 2" of room in the tightest spot, on top of the radiator. As you can see in this pic. the nostrals are up in front of the radiator, thats where your problem will be.
Car: 1987 GTA
Transmission: 4L60e
maybe take some more fiberglass and make a sort of tunnel over the radiator brace?? man I'm all out of ideas on this one. I like the look of the hood so much though.....but I wouldn't want a non-functional ram-air hood. Well....I've got to replace my front bumper this summer anyway. I'll draw up a paint file and post it with an idea I'm having.
little late , but here's mine (ASCD)
<img src="http://home.attbi.com/~cadek1/Picture002.jpg">
half is half wetsanded, LOL , maybe this summer I'll get to do the whole car
(I painted it myself at home in a driveway , not bad huh ?
) it needs a lot of wetsanding...
) it needs a lot of wetsanding... Member
Car: 91 Firebird
Transmission: A4
the Ram Air I hood is actually like the ASCD hood.. it's not quite right at the front of the hood, and slants back more .. the Suncoast Creations hood isn't like that.. I think the ASCD hood goes better with the body.. plus Suncoast Creations charges way too much.. I found some other place that makes them with functional airboxes for about $500-600.. let me see if I can find it..
--edit--
found it
http://www.ramairhood.com or http://www.advancedplasticsmfg.com/
they're both the same page ... only thing is they don't have Ram Air I hoods, just RAII ... for $645 functional. (at least for the firebirds)
also, with the ASCD and Suncoast Creations hoods, the fact that the ASCD hood scoops are a little farther back might make the functional part a little easier (might put the outlets back just far enough or high enough to clear the radiator) than the Suncoast one which is right at the front.
--edit--
found it
1992 Trans Am
May 10, 2023 07:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
