Finally my valve covers
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Finally i got my valve covers in place. Now the hole engine looks much better.
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
those are NIIIICE!! where'd ya pick those up from and if ya dont mind, how much did they set ya back?
thanks
Josh
thanks
Josh
i got mine about a month ago... there nice looking, but i cant figure out where to get a oil cap for it? the stock one doesnt fit, and i dont wana force it and start to have oil all over the place.. can someone help me? heres a pic of the valve covers.
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
Check mine out on my web page below.......Mine are hooked to a GM HO 350 Crate from Scoggin Dickey. Kinda lets the unsuccesful opponent know I am not stock!!!:hail: :hail: Later
Originally posted by Ryche400
To bigals87z28 . You can use any push-on breater. Like a K&N or a plain MR. Gasket one, it already comes with the right grommet. I had those same valve covers on my 91 Z28.
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Scania,
What type of header wrap is that and how did you get it on one each tube so tight and smooth?
Car: 1989 Corvette
Engine: 350 Tpi
I used thermotec Cool it. It took me 2 days to get it right and i didnt use water like many do.I used aircraft looking wire because its easy to hide the wire so it looks better. You will get a much tighter and smoother result if you dont use water on the wraps. Ohh and you need a lot of patience.
Originally posted by bigals87z28
but what about the oil cap? can that be reused? i never thought about the pvc... i thought that was a circle too? I need to know if there is a way to reuse the old cap or where to find one that fits.
Car: 1989 Corvette
Engine: 350 Tpi
Originally posted by Cliff92Z
Very nice.
You got a 305? How's the performance with those headers? They look good.
Very nice.
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Scania: what kind of header-wrap do you use? I live "a few" km south from you; since we don't have any Jet Hot agenda in Europe, I'm thinking 'bout this kind of tape from Summit. Is it so useful as they say?
Michal
Michal
Car: 1989 Corvette
Engine: 350 Tpi
Its thermo tec. I think Summit has it. Yes it works and it reduces the heat under the hood. I use the wrap because im afraid of melting wires and other things.
On the pictures you can see the bad gaskets that was included with the hedders and the bolts are lousy, i have to tighten them twice every summer.
Car: '89 GTA
Ooops, sorry for double posting, 89 IROC Z has asked the same Q before...
Just one thing; how much tape did it take to cover these headers? I guess it's 1 in. wide?
Mike
Mike
NBrehm
Aug 25, 2015 11:49 PM
