What's the best way...
Old Jun 29, 2003 | 01:46 PM
SS3933's Avatar
What's the best/easiest way to get paint off of plastic? Specifically, the rear tail lights (black part) on a 1990 IROC. Previous owner apparently painted them white and then painted back over the white with black! The flat surfaces aren't the problem it's mainly the grooved and curved portions. Seems like I've read somewhere about brake fluid being able to do this effectively. All opinions appreciated!
Old Jun 29, 2003 | 02:04 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
You might be able to sand it off and repaint them black.
Old Jun 29, 2003 | 02:40 PM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Paint thinner?
Old Jun 29, 2003 | 02:42 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
paint thinner will work wonderfly. just like dont go overboard with it cause i have no clue how strong it is when it comes to plastic. They sell some of that suff in a spray bottle...you spray a little bit on, wait a few minutes for it to become like a foam, then wipe it off....that was for metal when i used it so get something for plastic and make sure you follow the directions. if its not on too bad and if you'ev scraped most of the crap off, just a little bit of that stuff on a rag will probably get it off.:lala:
Old Jun 29, 2003 | 02:50 PM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
Im alao wondering, the plastic front bumper thingy, the nose on our 3rd gen, my paint is cracked, can i use a sander to get it off or what?
Old Jun 29, 2003 | 04:15 PM
SS3933's Avatar
Yeah I was thinking about paint thinner but like yourself I wasn't sure how the plastic may react. I got some steel wool, I';; try it first and see. Then maybe I'll try thinner or that spray stuff (got a name?)
Thanks, Chris
Old Jun 29, 2003 | 04:18 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
in a hobby store u can get paint thinner for plastic, like getting the paint of the windows on model cars
Old Jun 29, 2003 | 05:37 PM
you could do that or just get regular paint thinner or paint remover stuff.....even if it does react with plastic, i would think unless its something big that if you maybe dilouted the stuff with a bit of water and just put a very small amount on a rag and did it real quick you should be OK......but if your gonna have to go out and buy something anyway, go for the stuff made for plastic.....
Old Jun 29, 2003 | 09:28 PM
SS3933's Avatar
You know that's funny. I've probably built nearly 200 model cars over the past 15 years and you'd think I would have thought about that. I've probably got 2-3 cans in the closet now. I'll try that. THANKS
Old Jun 30, 2003 | 04:54 PM
Spdfrk1990's Avatar
paint thinner should be ok but will dull it out ull need to buff them afterwards
Old Jun 30, 2003 | 07:52 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
i used polishing compound to get the overspray off my taillights..just a suggestion.
Rousseau92maro
Feb 1, 2016 05:12 PM
trickedout02
Jun 24, 2003 04:53 PM
yanfoo
Carburetors
Jun 17, 2003 09:45 PM
TransAmTBI
Jun 9, 2003 11:19 PM
