T/A Tail Lights are on!!!! New way to wire lights too!!!!
Old Mar 26, 2004 | 07:42 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
I got the T/A lights on and they are sweeeeet!!!! Let me tell you what I did. I got a full harness off of ebay (with some lights that I did not want to use... just wanted harness). I take my T/A lights and drill a small hole into the back of the outer lens, splice the existing driving light with some longer wire and stuck it in (soft bulb holder) I then splice one of the other bulb holders for tuen signal....Little did I know then that I would stumble across the EASIEST way to get a full grid of driving lights. Tested this set up out and I did not like it........Flustered with my results, I take the small bulb out seal up the hole and cut the little bulb off. That is hen I noticed it.........The turn signal bulb holder was a THREE wire design. Dual filaments inside the bulb!!!!!! I started to get excited....sooooooo I strip the BROWN wire on the bulb holder and attach the BROWN wire from the little bulb harness......OH YEAH!!!! Worked like a charm!!!!!! I did the same on the other side!! See pics below:
Attached Thumbnails T/A Tail Lights are on!!!!  New way to wire lights too!!!!-img_0108.jpg
Old Mar 26, 2004 | 07:43 PM
here is one with the bulb harness in:
Attached Thumbnails T/A Tail Lights are on!!!!  New way to wire lights too!!!!-img_0109.jpg
Old Mar 26, 2004 | 07:45 PM
here is another...Please do not lock the thread mods. I want to post more than just three pics. This one shows the jumper wire to the running light harness:
Attached Thumbnails T/A Tail Lights are on!!!!  New way to wire lights too!!!!-img_0110.jpg
Old Mar 26, 2004 | 07:47 PM
This is a pic with the lights on:
Tell me what you guys think.......Later
Attached Thumbnails T/A Tail Lights are on!!!!  New way to wire lights too!!!!-img_0112.jpg
Old Mar 26, 2004 | 08:34 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
that one sharp lookin ride. Good work man
Old Mar 26, 2004 | 08:50 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Looks much better with the whole light lit up, nice work!
Old Mar 26, 2004 | 08:53 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
ya know what, u've inspired me to do that...
since i'll be home for a portion of my spring break i think i'll do that mod.
Old Mar 27, 2004 | 05:41 PM
BirdsofPray's Avatar
Car: 1991 Z28
Commendable work!
I'd suggest hosting your own pictures though. You'd be suprised at how much bandwidth is eaten up by just a few pictures.
Old Mar 27, 2004 | 06:14 PM
NEEDforSPEED's Avatar
looks awsome!
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
