Cool Or Dumb?
Old Jun 27, 2004 | 11:20 AM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
Cool Or Dumb?
on my '84 z-28, would a Holley Megascoop look cool or dumb?
thank you
Old Jun 27, 2004 | 12:57 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
i dont recall what they look like off hand, but most things with mega in the name look crappy honestly tho i dont like any kind of bolt/pin on scoops...
Old Jun 27, 2004 | 01:15 PM
Car: z-28 x2
http://www.holley.com/HiOctn/ProdLin...ics/f93157.jpg
Old Jun 27, 2004 | 01:51 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
unless your running a blower it would look really bad, kinda like a ***** with an electic blow off valve
Old Jun 27, 2004 | 03:18 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Is it functional? Even if it is there has to be much better alternatives
Old Jun 27, 2004 | 05:13 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Depends... what would be under this Megascoop?
Old Jun 29, 2004 | 04:24 PM
Car: z-28 x2
it will be functional (attached to the carb).
but no blower...
well i quess it will be butt ugly, now im thinking about it...
lets forget this topic okay?
its as stupid as these bottles of NOS fluid that you can drop in your tank, they selling here in europe... ( poor r!cers)
Old Jun 29, 2004 | 06:28 PM
Air_Adam's Avatar
Actually, last summer I saw something really cool, and its similar to what you are wanting to do.
It was on a '77 Trans Am that had a shaker hood originally. What the guy did was buy a regular flat hood (non-shaker) and a scoop. It wasn't the same scoop you like, it was the kind with the 3 red butterfly valves up front. Anyway, he painted the main body of it red to match the car, and cut the hood so that it would fit through tightly. It was cut out in the shape of the scoop so the lines matched.
BUT, the scoop was turned backwards, and only 1/2 way through the hood. This way it looked pretty close to the stock shaker, but from inside the car, you could see the 3 butterfly blades move.
IT WAS SO COOL!!!
Old Jun 30, 2004 | 11:53 AM
Car: z-28 x2
that is a very original idea...
its called a streetscoop, what i want is a megascoop, and there is also a hillborne scoop, same as the megascoop but round
Old Jun 30, 2004 | 04:41 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
It is effective in that it gets direct cold air into your intake. I love the look of the streetscoop style with the butterfly valves. You gotta have the right setup though. If your not running at least 12's its just poser material. Not that the scoop will do much to get you there, I just associate those scoops with blowers and real fast cars.
I saw this 78 Vette at the track big hole in hood with one of these scoops sticking out, I was thinking damn can't wait to see that run, then it proceeded to turn a high 14
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
Rally Smith
Sep 14, 2015 06:59 PM
